best turbo for daily driving?
Old Dec 8, 2004, 12:45 PM
  #31
Evoisdream's Avatar
hrmmmm im looking to get 400hp should i look moreinto the 3071r or the tme turbo? i cant decide ....
Old Dec 8, 2004, 04:46 PM
  #32
SurfguruJon311's Avatar
Originally Posted by evoland
Forced performance's TME turbo for $995 is the best bet. Titanium internals and the bigger 10.5 hotside. Better, qiucker spool, more torque and the torque is at a lower rpm. Great for street driving and great for mods. I recently put down 326whp with it, plus other mods too. Once I get some bigger injectors I will be close to 400 whp.
Sounds good!
What supporting mods are you running now and is this turbo a true TME turbo or a replica of some sorts? Also, does this turbo (for $995) just bolt up to the regular stock setup or will I have to get some supporting mods? Thanks for the help!
Old Dec 8, 2004, 05:21 PM
  #33
Ted B's Avatar
If you want 400hp, you'll have a much easier time getting there with a 3071. A TME turbo fits into a 350-370whp plan.
The 'TME' turbo is a direct replacement for the stock turbo.
FWIW, installing bigger injectors will not bring a TME setup from 326whp to 400whp.
Old Dec 8, 2004, 05:39 PM
  #34
Yea I was kind of thinking the same thing!
Old Dec 8, 2004, 06:30 PM
  #35
evoland's Avatar
The TME fits into whatever plan you want. It does bolt right up like the stock one because it's the exact same turbo essentially. It's still a twin scroll 16g, but the impellar( part that spins) is titanium, which gives you the better and qiucker spool with more overhead than the stock turbo as well. The TME turbo comes with the bigger 10.5 hotside like all the 05's get. The bigger hotside plus the titanium turbo= much better hp and tq than the hotside alone.
Old Dec 8, 2004, 07:57 PM
  #36
Ted B's Avatar
The TME does not fit into any plan much over 370whp.
The TME's larger hotside enhances midrange torque. Peak power is about the same as the factory turbo. The Ti wheel helps it to spool a little quicker, which offsets the slightly reduced gas velocity due to the larger hotside.
s240
11
Apr 5, 2016 03:31 PM
Sti Killer...
For Sale - Cars For Sale
Aug 21, 2015 11:59 AM
mizzay
25
Jul 14, 2014 09:28 PM
pwerks
38
Sep 21, 2009 08:42 PM
Travisivart190
13
Jun 28, 2008 08:25 AM
Quick Reply: best turbo for daily driving?
