best ebc on the market?
Old Jan 13, 2005, 10:34 AM
  #31
Z1 Performance's Avatar
I have found the AVCR too complex for its own good...its instruction book alone is a novel That being said when properly set up they work very well...I just have never had a car or need for all its features.
My two favorites have consistently been the HKS EVC5 and Blitz SBCID3, with the nod going to the HKS for its simpler setup and programming
...hint hint on where to buy any of these if you need one
Old Jan 13, 2005, 08:06 PM
  #32
ringmaster's Avatar
Originally Posted by WrX Kila
HKS EVC with the screen. Best Boost controller Period.
Okay, maybe we should say "What is the best EBC that you can still buy new with a warranty"?
Which HKS are you talking about, is it a current model?
I am getting a 3-4psi boost spike with my Joe P MBC and I want to change to an EBC to get rid of it. I don't think the Joe P is any worse than all the other MBCs, but the turbo spools so fast that you need a BC that can react to what is about to happen and start to open the WG.
Old Jan 13, 2005, 08:07 PM
  #33
housedj's Avatar
Thumbs up
i say go w/ the HKS EVC v, or Blitz SBC i-d for ebc's.
Old Jan 14, 2005, 08:41 AM
  #34
ringmaster - the EVC V is the one with the screen
Old Jan 15, 2005, 09:37 AM
  #35
GreedMOTO's Avatar
Hks Evc V --
Two settings for boost control ( I run one at 19.5 psi for street, one at 22psi for race gas)
Scramble boost for fun.
Fully digital display with peak monitering and peak warning.
Pretty easy (but long) install
Durable componants (meaning they will last in the engine bay)
HKS - You get what you pay for.
Old Jan 16, 2005, 09:12 AM
  #36
ringmaster's Avatar
I have a Turbosmart e-Boost on the way. From the technical info I have read on it and all the reviews, I expect it to be an excellent performer! I will report back after it is installed and tuned
No more boost spike like I get with my MBC....I hope!
Old Jan 16, 2005, 09:35 AM
  #37
EvoTio's Avatar
I have a Profec B and it's great! Used it on my Talon for a number of years and now it's in my Evo. Holds boost solid until redline.
  #38
BrownPoop's Avatar
Originally Posted by JohnnyTwoThumbs
The Profec B is an awesome unit, if you take the time to understand and set it up properly. Hold like a rock, just needs fine tuning to get that way. I love it.
agreed, I had the Profec B on my sr20det and it did a good and consistant job of controlling the boost. I liked how simple this unit was.
on my old Poopra I had the HKS EVC Pro, which by the way had an insane amount of features, which also worked flawlessly. However, this unit was very complicated to set up so I had to have an HKS pro shop do it.
Old Feb 20, 2005, 03:10 PM
  #39
UT_Evo's Avatar
So basically the problems people are having with the Profec B are just not setting it up quite right, that's what it sounds like? I've been looking at getting an EBC for a little bit now (my stock boost solenoid is peaking it at ~16psi).
Old Feb 20, 2005, 05:01 PM
  #40
TimmayEvo03's Avatar
Where exactly are you guys mounting these MBC's? I had mine mounted where the stock one was and the boost was all wavy and weird, so I made a little bracket and mounted it right next to the turbo and now the boost will hold at 19 or 20psi up until about 5800RPM then it goes up to 23 and holds all the way to 7500RPM! The instructions state to mount the MBC as close to the turbo as possible which it is now, but I'm lost here on this one with the boost not holding!
06AznEvo
Jul 13, 2017 12:34 AM
5k6
Mar 21, 2017 11:18 PM
Paulevo9
Feb 20, 2016 03:03 PM
mines hotter
Jan 6, 2008 10:24 AM
erggy
17
Oct 20, 2005 05:32 AM
Quick Reply: best ebc on the market?
