Greddy Type RS bov pic installed
#31
When you get it, if you don't mind please post a pic of the recirc/outlet adapter... does it replace the blue part or somehow fit around/over it? And I'm looking forward to hearing your sound (or video) clips once you start recirculating.... If you can record going for a drive, that might be better too since it's probably a lot louder under load than in neutral...
#33
The only way I know would be to run a stand alone EM system. It has to do w/ your maf sensor, and when it sees air, it sends fuel, but then the air is vented to the atm, and causes a rich condition.
I've got the worx tuning bov. It is completely adjustable from 100% vta, 75/25, 50/50, 25/75, and 0%. If you want the sound, but not the loss of drivability, then you need to at least go w/ a 50/50 bov so that some air is put back into the intake tract.
#35
Hey guys, I am from the dsmtuners board, just got one of these BOVs as well. Love the look, but does anyone know if someone other then greddy will be releasing the recirc adapter sooner maybe?
#40
Originally Posted by AZGSX
99AllTurbo, where were you able to order the recirc kit from? Also what is the diff. between the sizes of the tube.
edit: Diff between the size of the tube? Not sure what you mean exactly. I ordered the 29mm outlet adapter (recirc adapter). The tube where the stk bov fits into at the intake hose is 27mm. The 29mm recirc adapter is the size nearest the stk tube. Hope I made sense.
As for the sound. I may not know for sure, but it should not make a difference if the valve is recirculting or not, the sound should remain the same. The Type S sounds the same whether vta or recirculating. Therefore I feel this bov will have the same sound if recirculted.
#41
Originally Posted by kondo
Is there anyway to run a BOV VTA that wont make the car stall? I am still all stock besides my tint, my dealer said a BOV VTA would not void my warrenty.
#45
I heard about the HKS EIDS, does that really work? Anyone running it? Any stalling issues while VTA? I'm really interested in purchasing that module and would like to know more info and experiences that you guyz had with HKS EIDS..
