Where 2 buy 10.5 T housing
Old Dec 10, 2004, 05:25 PM
Aby@MIL.SPEC's Avatar
Besides forced performance, where can I buy the 10.5 turbine housing for a '03 evo 8 & for how much?
Forced performace has them new for ~$260.
Does anyone have a source for used pieces?
thanks
Old Dec 10, 2004, 05:37 PM
MalibuJack's Avatar
You can get them from Japan or Taiwan, but ends up costing about the same.. the new 05 turbine housing is also about $260 from Mitsubishiparts.net You really won't find many used ones because the US market just didn't have any until this year.
Old Dec 10, 2004, 08:01 PM
n00dle's Avatar
Just curious if you've got a part number?
The one I have is MD613524 and goes for $510.
Old Dec 10, 2004, 08:08 PM
MYEVOVIII's Avatar
Or from www.Dyno4mance.com
Old Dec 10, 2004, 08:13 PM
MalibuJack's Avatar
I'll take a look, but I'm fairly certain that its listed in the Evo Parts thread.. JustDSM supplied me with most of the part numbers I needed..
I do recall it came up as $250 or something like that.. around the same price as the Compressor cover.. but who knows anymore..
Old Dec 10, 2004, 08:15 PM
KillaSweep's Avatar
will replacing the the 03 turbine housing with the new 05 turbine housing basically make it perform like an 05.....as far as the engine and turbo go?
Old Dec 10, 2004, 08:18 PM
n00dle's Avatar
That's where I got the number from. The compressor cover checks in, but I was surprised with the turbine housing. Wonder if '05 10.5 housing is any different from prior models...
Old Dec 10, 2004, 08:27 PM
Zeus's Avatar
Which piece was this?
Old Dec 10, 2004, 08:29 PM
n00dle's Avatar
Supposed to be the turbine housing. Here's the info JustDSM posted.
'03-'04 All Trim levels
Compressor Housing: MD613567
Turbine Houshing: MD613521
All '05 Trim levels
Compressor Housing: MD613573
Turbine Housing: MD613524
Old Dec 10, 2004, 08:31 PM
turboDan's Avatar
Or you can just get the whole T.M.E. turbo brand new for $899.00.Now that is a "Steal"
http://linux.forcedperformance.net/m...ode=Lancer_EVO
Cant go wrong for that price.BTW,these are brand new,from japan and are the real deal.
Old Dec 10, 2004, 08:46 PM
MalibuJack's Avatar
It is different, it has a different wastegate flapper.. But otherwise it interchanges and the O2 housing will bolt up..
I'm just surprised that its $500 bux.. the CHRA is $700 according to that site.. cheaper to buy an entire turbo assembly after adding up those parts.. I wonder if when I looked it up, that it was entered wrong.. I know these units new from japan (the older style 10.5 housing) are only $250
Call Forcedperformance, they used to have it listed as a seperate part on their site that you can buy outright..
Old Dec 10, 2004, 08:58 PM
n00dle's Avatar
It's certainly cheaper to get the TME, but if i'm not mistaken here it will not have the identical compressor and turbine housing as the '05's, which may account for some of the impressive gains we've seen over '03-'04 and this is without the TiAl wheel. New turbine flapper and perhaps increase compressor housing volume may seem small, but may also account for something. There are a couple of routes to choose from with different housing options....
Old Dec 10, 2004, 09:12 PM
MalibuJack's Avatar
Definitely, I have the new compressor cover and it definitely appears to be a bit larger, I don't know that the revised flapper in the 10.5 turbine housing makes all that much of a difference in itself.. But I have the old 10.5 housing, and the new compressor cover.. combine that with the Titanium CHRA, and the (soon to be released) 20G wheel and I think you have the ultimate street turbo..
Old Dec 10, 2004, 09:17 PM
n00dle's Avatar
I've been keeping an eye on that 20G wheel developement.
Hope things work out, but I do have a concern about it.
My concern is the wheel exploding. Do we know how the wheel is being made, what material, and what quality control measures it will go through?
Old Dec 10, 2004, 09:24 PM
MalibuJack's Avatar
My guess is its being CNC machined out of billet.. high-quality castings dont seem very practical in small quantities however a blank casting of a 20G wheel, cut to a mirror image on a CNC machine is certainly possible.. You won't have it coming apart unless the machining process is leaving high-stress areas (square cut corners as opposed to fillets and rounds) that aren't cleaned up... I would home the material is stress relieved before being used after the machining/manufacturing process.. (I plan on having the unit cryo treated if they haven't already during manufacture)
Quick Reply: Where 2 buy 10.5 T housing
