Install help on Defi Water Temp sensor
I have the Defi BF water temp gauge but haven't found out how others have installed it. For those of you who have this gauge, could you please provide me info on your installation?
BTW, I did try the search button....got nowhere.
I too will be in that same process. I figured that if I use the option of adding a adaptor that you install inline on the top radiator you could install the thermal couple for water temp there. I know Greddy has those adaptors. Also if you plan on adding oil pressure and oil temp, Greddy also sells those adaptors to add to your oil filter. I hope this helps.
nbpal4000
Sep 9, 2005 03:51 PM
