help with boost guage
Originally Posted by RealVibes.net
i just took it for another spin to see if it happens in all gears and it surely did, the highest i saw was 13-14 psi tapering to 10-11 psi. i double checked all the hoses,etc and did not find any leaks. i am out of ideas.
I have the same problem On my 05 MR, going to about 14 psi .9bar and tapering to .7bar think is about 11psi, Im suppose to have my friend check for boost leak sometime next week. The stock boost gauge from mitsu is tapped into the fuel pressure sellenoid on my car Im curious wth is going on with my new car as well....
the guage reads just about - 18-20 at idle, i think i may have figured out the problem, i think when the person took out the boost controller they just replaced the vacum lines with regular ones, not the ones from the factory with the little nipple in it. i ordered a new set of lines from mitsu today so i will know tomnorrow if that is what it was, i will keep u guys updated.
its probably the small hose that is connected to the turbo outlet. thats the only one i know that has a nipple in it. theres probably more , but from what i read thats the main one that has caused people problems / or the low boost
Originally Posted by x7eVoLuTiOn7x
When you get to high boost of like about 19 psi, are you in 5th gear? or can you hit 19 psi on 3rd at 7k rpm? Never had a boost gauge so im kinda confused.
Originally Posted by Ev0 1
I believe you can hit 19psi in 3rd gear, I hit 20psi in 3rd gear. You should get a boost gauge.
Also if you got a manual boost controller how can you set it up to like 21 psi? I have no clue!
https://www.evolutionm.net/forums/sh...0&page=1&pp=15
here read this try doing a search its been discused
the good the bad the ugly on each of the places..
well i just picked up the hose kit from mitsu. and installed it, and the car is running perfect now. it is boosting all the way to 19 and then tapering to 16-17. thanks for all the help guys.
evo 9 guy
Nov 16, 2010 11:49 AM
