Polling interest- GM Maf Translator Conversion
I am wondering how many people would be interested. I am currently talking to Ongreenperformance.com and if I can get 10 buyers they are willing to work a group buy price. The 2G setup is fully compatiable with our cars and they have setup about 10 on Evo's so far with great results. Right now they are only $280 shipped.
Here is some info I got from there site On Green Performance
They have pics on there site.
2G Maf Translator
This is the device that allows you to run the Below 3" GM Mas, It makes the installation basically plug and play with only 1 wire to tap. Not only do you get a much less restrictive higher flowing Mas/Maf, but the Translator also allows you to tune fuel curves, making the need for a fuel computer for basic setups unneeded. Much easier and more useful then the 2G mas set up, also easy to reverse if you ever want to, does not require you to cut the stock plug, this set up makes a 2G Mas seem like a 1G Mas--It flows. Also works on the 3SI Cars.
3" GM Mas
This is an excellent upgrade for the DSM community wanting to make 400+ HP, on either a 1G or 2G Eclipse/Talon. When used with the Maf Translator, it allows you to remove that restrictive karman Vortex style Mas and Replace it with this much less restrictive hot wire set-up. It can be used in either a blow threw or draw threw application. This picks up where the 2G mas falls off.--See Intakes for Filters and Pipes to fit this. (All Mas's are low mileage used units-Pretested and work great)
2G Maf Translator
3" GM Mas
The Gm maf set up as a blow through setup will also allow you to VTA if you have an aftermarket valve with no chance of having any problems at all. This setup is very similar to the one that Ultimate Racing use to offer at over $600. This setup is half the price and if you every damage your GM maf you can get another one for only $75. These are pretty hot items in the DSM commmunity also. I did a setup on my buddies DSM. Really easy to install with only one wire to tap and you can go back to stock anytime.
I inquired about it, and fullthrottlespeed said their were some issues with the calibration between the 2G MAF and the EVO MAF's output frequencies.
I don't have any direct data, but I've got some information that indicates the two MAF's do not output the same frequency for a given airflow ammount.
Has something changed in the last month or so since I've talked to them?
I will check into the differences between the maf's. Thanks for the info. I think as long as you tune for the maf it should be ok as long as they output the same range although they may meter differently. Definitely something I will look into.
Sorry for the late reply. I was out for the Xmas holiday and didn't get to a computer. Hope everyone had a good holiday.
There is a calibration difference.. The MAF signal ramps quicker on the Evo than it did on the 2G
This item WILL work.. However please be aware of the shortcomings of this kit over the one UR was selling (www.pro-flow.com is the blowthrough MAF setup I'm using)
the GM MAF can be prone to damage from vibration and high velocity airflow, the Ford Cobra unit (used in the proflow) is suspended in the airstream differently and is therefore less prone to damage.
calibration is calibration, if you can tune for it, or calibrate the unit itself, then your OK..
the OE Maf sensor on the EVO has a 1bar MAP sensor, and Intake air temp sensor, both are used to influence the signal output of the sensor.. the Pro-Flow Converter has these sensors, and utilizes them for consistent results in any weather. As far as I know, this is something this unit does not do. I also think it may not have the temp or map sensor components but it may "loopback" those sensors (hopefully you can add your own) therefore the factory ECU will no longer have these inputs to compensate for conditions.
Do your research.. www.pro-flow.com is what I'm using.. but the main advantage of your unit is price.. So weigh the features and your options before you buy.
Also be aware that the 2G MAF plug is different, so it has to be spliced into your current MAF wiring, or salvage a MAF sensor plug from a broken MAF sensor.. Also, calibration takes time, this unit will need to be calibrated before you can reliably use it.. You will need a way to read and compare the MAF readings of the stock sensor and your new setup..
Just keep these things in mind, otherwise, either one will work well..
Yep.. But the wiring left to right is the same.. Both are 7 pin connectors, and functionally all of the MAF sensors with seven pins work the same regardless of which Mitsubishi it came from.. the calibration and physical dimensions (look of) the MAF varies..
This item, along with the Pro-Flow will work on any Karmann sensor equipped car, some may take more work than others to get working right, but it will work.
