Unofficial 2.4 Blocks Thread
Yes
Keith,
I got the above #'s from this thread:
https://www.evolutionm.net/forums/sh...d.php?t=103471
I am still in the process of gathering research for myself, which is better the 2.4 block or a stroker kit with a bore.
At this point, I am leaning towards the 2.4 block as the block is bigger and you are not changing the characteristics as originally intended for the stroke of the internals as designed from the factory. You would have to add oil squiters and this engine was not originally intended for boost.
Also, I do not know if the 2.4 block has the same oiling and cooling passages as the 4G63.
Originally Posted by Fourdoor
Only if you overbore the 4g63. The EVO's are so new that many people are using stock sized replacement pistons without even doing a hone let alone a rebore of the block.
Keith
Keith
Originally Posted by Big Boost
<snip>
At this point I don't speak from personal experience and I am merely bench racing. However, if I can come close to or match the displacement of the 4G64 by stroking and punching out the 4G63, I'll stick with the 4G63. It's "ready to go" with no modifications necessary to accomodate the oil squirters. You also don't need to hassle with the taller deck height and associated cam gear and cam belt issues.
At this point I have been working with Jackson Auto Machine to spec out my build. I would highly recommend that you give them a call and talk to Carmella or Jerry. You may end up getting roped into a half hour conversation but you'll probably get some good information regarding building a stroker.
Originally Posted by propellerhead
How far can you overbore the 4G63? Can you punch it out to 86.5mm without issue? Magnus sells 4G64 overbore pistons in a 87.0204mm size so it seems that you can reduce the cylinder wall thickness quite a bit as long as your not planning on putting down insane amounts of power. FWIW, RnR is putting down over 600whp on a 4G64 with a 86.5mm bore so assuming that all other things being equal between the 4G63 and the 4G64, cylinder wall thickness might not be an issue.
Actually, the rod length and the stroke of the 4G64 are the same as that of a 4G63 stroker. The difference with the 4G64 block is that the deck height is 6mm higher. This is the reason that stroker pistons for the 4G63 have to have the wrist pin moved up 6mm, otherwise they'll stick up out of the block. My conclusion is that the 4G64 and a stroked 4G63 both "suffer" from the same rod ratio issues and redline limitations. I *think* that these issues can be mitigated to a certain degree by doing a careful build in terms of blueprinting the block and balancing the rotating assembly. By properly boring the cylinders round and perpendicular to the mains, ensuring that you've got the right piston clearances and using coated piston skirts I *think* you should be able to reduce the effects of the high side loading created by the low rod ratio. Despite what has been said regarding safe redlines, you'll never run a 4G64 up to 9,000 rpm for extended periods of time. A more realisitic safe redline for a built & balanced 4G64 is around 7,800 rpm.
My view differs from yours in one area though. I would prefer the 2.4 block for one simple reason. I don't like putting the wrist pin that high up on a piston. You have to push the rings higher up on the piston, and put the rings closer together to get room for the wrist pin and in my view you end up with ring lands that are two thin and too high up to be as strong as I want in a very high HP / high torque motor. You could get around this by using shorter custom rods.... but that would make the rod/stroke ratio even worse and be expansive as well.
Later,
Keith
Keith,
Later,
Keith
Yes, we are currently one of only 2 selling the built 2.4 blocks. They bolt right in and work very well for a very good price. On our shop car we made 630whp and 610ft lbs at 30psi. This was on a GT35R w/equal length manifold. We are currently reving the car to 8500rpm without any issues at all.
I will go into more detail when I get some time about the big advantages of using a 4G64 over using a stroked 4G63 block.
RNR More INfo
Originally Posted by RnR Racing
Yes, we are currently the only ones selling the built 2.4 blocks. They bolt right in and work very well for a very good price. On our shop car we made 630whp and 610ft lbs at 30psi. This was on a GT35R w/equal length manifold. We are currently reving the car to 8500rpm without any issues at all.
RNR,
I am bring this thread back from the dead, as there is another thread about a 2.4 vs a 2.3 stroker kit. I would like to hear about the big advantages.......
The 2.4 is better because the block is taller, so that alone gives you more potential for displacement and the standard cylinder bores are larger, this alone give you a better rod ratio, rather then using the longer rods in the shorter 4G63 block.
Originally Posted by ShapeGSX
The displacement of a stroker and the displacement of a 4G64 is the same.
why do you need oil squirters in this block?
btw... to answer the thread question... roadrace service also makes these to order.
Originally Posted by trinydex
you're gonna have to clear this up for me and maybe show some proof cuz i keep hearing that the galant 4g64 has more bore than the 4g63 and it's not just stroked. set me straight.
and i have an additional question for propellerhead... wouldn't the 4g64 have a larger rod ratio... and hence not suffer from the limitations that you were talking about?
http://e30m3performance.com/tech_art...ratio/kin2.htm
and also according to this... it seems like changing rod ratios albeit are bad for the ring placements don't increase or decrease the rev capacity for the engine that much. it's like splitting hairs. they performed their example with 1cm of change and it only yielded about 200 rpm difference... if we're talkin' almost half that... i doubt there will be issues.
The difference in bore between the 4g63 and 4g64 blocks (if the info posted above is correct) appears to be 1.5mm, or 0.060", which could be significant if the cylinder walls in the 4g63 block do not have the same wall thickness. If this is the case, I would be most cautious about performing that size overbore in the walls of a motor that is going to be asked to make a great deal of power.
Additionally, swinging a comparatively large 100mm (3.93") stroke in that small engine creates a highly undersquare situation that puts substantial stress on the bottom end. Meticulous balancing and solid bottom end support (e.g. main studs and straps) are smart propositions.
And finally, as Fourdoor mentioned, lengthening the stroke with no changes in rod geometry is fine to a point, whereby the oil control ring is pushed into the piston pin, and the ring lands are so near the crown that the top of the piston becomes thin and less durable. I haven't seen a piston intended for a stroked 4g63, but the increased 4g64 deck height probably makes for a better/stronger piston.
Okay, it's my limited understanding that rod ratio has a larger bearing on piston sidewall loading (and subsequent wear) than it does on overall RPM limits. Naturally side load will limit maximum safe engine speed to a degree but what I was looking at was mean piston speed.
With a 100mm stroke, mean piston speeds in a 4G64 (or stroked 4G63) @ ~7,800 rpm is approximately that of a standard 88mm stroke 4G63 spinning at ~9,500 rpm. Also, the maximum g forces experienced as the piston comes off TDC with a 100mm stroke are MUCH, MUCH higher than with an 88mm stroke.
And yes, as Ted B and others have mentioned, without the extra deck height the wrist pin ends up being pushed up 6mm into the region of the oil control ring. In the motor I had built teflon support "buttons" or plugs are inserted into the wrist pin bores to help support the oil ring.
Ideas or comments are certainly welcome.
With a 100mm stroke, the piston travels 200mm/rev, which at 7800rpm = 26.0m/sec
As far as I can tell, the 88mm stroke equivalent at a piston speed of 26.0m/sec is 8863rpm.
For perspective, this is the same piston stress equivalent of a 5.0L Mustang GT engine turning over 10,000 rpm.
