ATP GT3071R HP and BOOST?
Hey! Merry Christmas!
Question....
I just purchased the ATP GT3071R Ball Bearing Turbo kit for my 8.
Here's the list of Mods... Can someone tell me what kind of HP range I will put at the wheels? Also... Im running 21lbs now on stock turbo... but with the kit, what should i run? Its my daily driver. And I drive about 40 miles a day... FYI...stock internals..heres my mods:
Psi Fi Motorsports Piggy Back ECU
AEM intake
MR Diverter Valve
Greddy Front mount with lower IC piping
HKS Cam Gears
HKS 264 Cams
Perrin Fuel Rail
Greddy 720 Injectors
Walbro 255lph Fuel pump
Helix Downpipe
Espelir cat back exhaust
Invidia Test Pipe w/ CEL Elim.
TurboSmart Electronic Boost controller
Goin in after X-Mas... ATP GT3071R kit and TopSpeed FPR
And always 93 octane gas...sometimes 94
So.... What HP can i expect to the wheels..and what boost? Anything else MANDATORY for this setup for a safe; daily driven monster?
Thanks!
Question....
AEM intake
MR Diverter Valve
HKS Cam Gears
HKS 264 Cams
Perrin Fuel Rail
Helix Downpipe
Thanks!
You should see 320 whp on 91 octance with 22 psi, 350 whp on 100 octane with 27 psi, give and take a few HP. All HP # are on DD dyno. BTW make sure you check the wastegate spring before install, you might want to use the stock oil return metal tube for better sealing, because the one from the kit leaks. You'll have to cut the stock tube and use a rubber tubing with clamps. Good luck with the install. Post up the result, let us know how it turn out...
Oh yea..I have the ARP head studs goin in when Psi Fi does the install ![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
I forgot to post that in my mods
I'll be sure to make note of the stock oil lines..thanks!
I'll keep everyone posted once everything is said and done..along with dyno sheets![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
More feedback please!!
Thanks!
Thanks!
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Thanks!
Thanks!
Originally Posted by propellerhead
He's talking about DynoDynamics numbers.
Yea I noticed a slight leak on the bottom of my oil pan too for awhile, but it seems to have slowed to a nothing. I check my oil and over the span of a month I hardly lose any oil so I don't worry about it.
