Big turbo guys in here
Originally Posted by Widebandphillip
Oh this is for an ls1? screw the greddy t-67 go buy a garret gt42 88mm and be done with it.
Originally Posted by EVO8LTW
So what's going to be faster? The Z or the Evo? You should run a high 10 in the Z28 on slicks if you've got the drivetrain bulletproofed. Glad to see another modded Evo/modded Z28 owner in NoVA. My Z is a lot slower than yours (best 12.2@113 NA) though.
The EVO is going to be faster than my LS1 running race gas pushing 32psi or so for now. My LS1 did trap 123mph running street tires and slipping clutch. So there is 126-128mph in it and 10's with ET streets and a stronger clutch. I have got a bulletproof drivetrain already running 8.8 inch rear end and chromoly Drive Shaft. The only weak link now is the Mcleod clutch. It just cant give me a good 60ft and it starts slipping bad on the 3rd and 4th gear which lead to a 123mph in traps and a really bad ET for now. Although my LS1 will end up faster than the EVO when all done later on(Forged bottom end pushing 16-18psi).
ATP turbo has those housings for sale. Its a T04S compressor housing by the way...not necessary has to be the specific one for the 35R...Try them, I just made an enquiry and they seem to have it...
Run the 1.06 A/R turbine housing on the 35R for your LS1, has slightly more hp due to the better efficiency and you have the cubes for it to spool up decently... I'm running one on my Evo 3, pulls 143 mph on the traps...
HKS T04Z,here the links:http://www.hksusa.com/products/?id=1993
Originally Posted by badlooser
AMS is coming out with a GT 40 and a GT 42 turbo kit which should be good for 825 flywheel hp and trap speeds in the 140+ range with out alchohol injection or NOS.
Originally Posted by bolsen
just a little bit more.... just a little more... 5000rpm.... just a little more.... 6000 rpm.... just a little more..... 7000 .... 7500 BAM ful boost! 8500 SHIFT!
they have not relesed and specs yet they are still testing but if you look at their GT35RL kit they are on full boost by 3900 rpm. You obviously dont know anything about gt 40 turbos they will spool before 7500rpm! Why dont you stick to smaller turbos. just like you pen*s.
Wow, you got me there...
And since you seem to know everything about me, if you can tell me the specs of my turbo I'll paypal you $10. So put your money where your mouth is Mr internet tough guy...
matt1937
May 27, 2017 03:31 PM
ottoman
20
Oct 12, 2011 06:00 AM
AutoMotoSports
Automotosports - Illinois
43
Oct 28, 2010 02:22 PM
