injectors?? OK to install??
wut up evo junkies!! I got some greddy/denso 720cc injectors and was wondering if you can just install something like that and the car will still idle and run fine? I plan on getting the car tuned with them as I know that will be a necessary step. However, what would happen if I just bolt them on? I have quite a few mods so there is a need for more fuel. thanks all.
Larger injectors are not a drop-in and forget mod. If you install them, the car will run far too rich, the computer will be confused, and you'll likely get a CEL.
In any case, if you don't have a means of adjusting for the larger injectors, you more than likely aren't making enough power to use them anyway. Install them when you have a means of tuning for them.
David Buschur
31
Nov 2, 2009 05:55 AM
Inprogress
17
Mar 2, 2008 01:42 PM
SuperchargedGTZ
May 11, 2005 03:55 PM
