Should i lower my boost????(merge)
I got my AMS turbo back exhaust and will install it tomorrow. I've heard a full exhaust will raise your boost automatically. Im currently boosting 20 until redline with the help of a hallman MBC, yet i dont wanna blow up my motor if this is true. Any help? also what do you think of this exhaust if you have it? looks good so far.
With a hallman in place your boost shouldnt raise with the new exhaust installed- you should be fine!
I believe if you are still using the stock solonoid to control boost - it would raise a few psi.
I got my AMS 3" TBE and i heard it would raise my boost automatically. Im currently boosting 20 to redline with the hallman MBC. Is this true or not? Also is running 20/19psi to redline safe in the evo? thanks
Im pretty sure that adding a tb exhaust will actualy lower your boost since there is less load on the engine. When i had my exhaust without a boost controller I was hitting 1.2 bar(17.5 psi), which is lower than stock by 2 psi.
Originally Posted by JESSEFREITAS
an exhaust will lower your boost if anything, not raise it.
