APS High Flow Intake Manifold
Old Feb 16, 2005 | 11:38 AM
RallySport Direct's Avatar
Silver Sponsor
I talked to APS about it and they have not been able to get me a price for it yet. I will hassle them as soon as they wake up and see if they can at lest give me a ball park figure to give to you guys. I will let you know as soon as I find anything out.
Ben
Old Feb 16, 2005 | 02:07 PM
MalibuJack's Avatar
Cool.. THe other thing it doesnt mention is what their going to supply (if anything) to drive the secondary injectors.. I already have something in mind, but that will affect its price I'm sure..
Old Feb 16, 2005 | 02:25 PM
2k4EvoVIII's Avatar
Ben
There is nothing new here. APS has advertised this intake for awhile now. Here is some info on it.
The APS High Flow intake manifold for the Mitsubishi Lancer Evolution represents a massive improvement over the stock component.
By removing the primary runner dog-leg, which is a provision for right hand drive installation, primary runners are now straightened and the inlet port floor approach angle is now maintained. Along with a 20% tapered runner cross sectional area, charge air flow through the inlet manifold is significantly increased throughout the RPM range.
Extensive development has gone into the plenum chamber design in order to achieve what is arguably the ultimate EVO intake manifold for left hand drive applications. Volume has been significantly increased along with a corresponding increase in entry size to accommodate larger throttle body mounting.
Most significantly of all, the APS High Flow Intake Manifold is supplied complete with provision for a set of four auxiliary Bosch style fuel injectors, custom 5/8 inch I.D. fuel rail and high quality fittings.
When used with appropriate engine management, this is a true 650 Horsepower intake manifold.
By the way i went to your website and your lift numbers are wrong for the HKS 280 intake cam. The Exhaust cam has 10.2mm of lift but the intake has 10.8mm of lift just like all the rest. I got my set today and according to the paperwork thats what is says even though the HKS website states otherwise. Anyway just thought you would like to know.
Chris
Old Feb 16, 2005 | 03:58 PM
Silver Sponsor
I will check to see what I can find out as far as running the secondary injectors
Chris
We got the numbers from our HKS list and on ouir sheet is says that both the intake and exhaust cams are both 10.2mm lift but i will check into it thanks for the heads up
Old Feb 16, 2005 | 04:14 PM
superz's Avatar
Hey Jack, you must be going with a big turbo (35R) if youre considering 8 injectors? What are you up to bro I ran 785cc injectors with just a reflash and my driveabilty was as close to stock as can be. Spill the beans
Old Feb 16, 2005 | 04:33 PM
2k4EvoVIII's Avatar
I got the Cam Specs with my cams straight from HKS. I can scan them in and send them to you if you like?
Chris
Old Feb 17, 2005 | 12:09 PM
Silver Sponsor
That is ok I will just call my HKS rep and yell at im for giving me bad specs Thanks for hte heads up I will have our web guy change it today.
APS says they are shooting for a $600 MSRP on this intake manifold. Hopefully we will get some numbers from it. The good thing about this manifold is that it is cast. Sheet metal manifold sometimes have a tendancy to resonate and cause problems. And if not built properly can crack.
Ben
Old Sep 12, 2005 | 08:43 PM
Kornmart's Avatar
so anyone get this thing yet??? What does everything think about it?? I know some time has passed since this thread has had the last post, but I did a search, and this one seemed to be the best discussed about this manifold. Thanks!
Old Sep 12, 2005 | 08:50 PM
RyanM's Avatar
I checked on this with RallySport Direct last week, they never actually made a production unit. Kinda sad, it looked like a great piece!
Old Sep 12, 2005 | 08:51 PM
spoolingEVOx's Avatar
..such a shame
they have been advertising the intake manifold and turbo upgrade for some time now with not one single production unit on the market.
seems like a waste of advertising dollars IMO
Evo11V
13
Jan 11, 2016 12:42 PM
Vivid Racing
Vendor Classifieds
Aug 2, 2012 05:54 PM
Mark@AMS
Automotosports - Illinois
49
Aug 31, 2010 08:42 AM
Mellon Racing
193
May 13, 2010 08:08 PM
911_Evo
40
Jan 28, 2010 03:42 PM
Quick Reply: APS High Flow Intake Manifold
