T bolt clamp measurements for IC piping?
Old Feb 18, 2005, 08:14 AM
RalliArtEvoVIII's Avatar
which 1 of these is the right size for all my IC piping from the turbo to the throttle body? thanks!. Also which clamp is the rigth size for my intake to lock onto my turbo inlet. thanks
Clamp (2.25") -- Range 2.125" to 2.625" Approximated
Clamp (2.50") -- Range 2.5625" to 3.00" Approximated
Clamp (2.75") -- Range 2.625" to 3.125" Approximated
Old Feb 18, 2005, 09:06 AM
Old Feb 18, 2005, 09:10 AM
sleet's Avatar
Get all 3 and return the ones you don't need...where'd you buy yours from? I've been looking for one, would home depot have em?
Old Feb 18, 2005, 09:38 AM
eBay...thats why im deciding which ones i need cuz i dont wanna get the wrong sizes and have to ship em back, etc..
Old Feb 18, 2005, 10:38 AM
Zeus's Avatar
Try NAPA... they usually stock them.
Old Feb 18, 2005, 10:42 AM
matt55's Avatar
Napa is da sh*t , i had to get 3 diff sizes , the one's for the lower ic pipe napa didnt carry .... good luck
Old Feb 18, 2005, 10:44 AM
blackevoVII's Avatar
so then napa is just sh*t rather
Old Feb 18, 2005, 10:45 AM
sleet's Avatar
Anyone got a specific size for the top IC pipe? Right now i've got 2 clamps on it holding it on
Old Feb 18, 2005, 10:46 AM
Evoisdream's Avatar
ok i just went through this for about 2 weeks orderd 5 that fit the normal pipes but i needed one to fit from the ic pipes to the manifold which one do u need exactly and ill let u know
evoisdream
Old Feb 18, 2005, 11:06 AM
GOKOU's Avatar
Take it from me since I also ordered from ebay and mess up. I have BRS4 setup. Depending on what silcone coupling you use the intercooler piping will be 2.5" (BR silicone coupler). If the coupling is thick then get 2.75". For the throttle body it's 2.75"
All I can find at Napa was 3" or bigger which sucked!!!!
Old Feb 18, 2005, 11:17 AM
mitsuorder's Avatar
hold one, searching for my "post-it" note diagram I made for my own reference last year, oh man, I'm looking at a sea of little yellow papers
Old Feb 18, 2005, 11:26 AM
glgz's Avatar
Heres what I did when the my clamp went bad on my throttle body. I went to a local place that sells parts for semis (rigs). I think size was 2.9 to 3.1 roughly. The style I put on is the big metal band with a spring loaded nut that you tighten down. I have not had any problems at all since then. I found all this out from a buddy of mine who is a trucker driver that rigs intercooler pipes and connectors are about the same size as ours. And it only cost me $5.
Old Feb 18, 2005, 12:17 PM
Widebandphillip's Avatar
most of the intercooler pipes are 2.5" but the throttle body is a 2.75"-3"(either one will fit) The Inlet of the turbo is a good 3" with the coupler on there. I'm not sure what the turbo outlet size is though. Probably a 2.25"-2.5"
Old Feb 18, 2005, 12:21 PM
mrbkkt1's Avatar
all i know is that a 300 is to big, i bought several and haven't had time to return them yet. i was going to switch to a 250 . The 75 is good for the bov though, but i took them off. i keep adjusting the bov, and when i finally get it done right, i'll switch for the tbolts. i think the 300 is good for the throttle body though. If anyone needs a guarantee place to get them, i buy mine from an air/hydraulic supply store, here in hawaii called hydra-air pacific. i think almost any of these types of shops will have em.
Old Feb 18, 2005, 02:35 PM
mitsuorder's Avatar
ok sorry guys couldn't find it for the life of me but I am fairly sure that IF you are using the stock i/c pipes you will need 3 of the tbolts that can go to a minimum of 2.25", you will need ones with a minimum of 2.5" for where the pipes connect to the stock endtank, now if you go up to 5 ply silicone couplings you will have to account for that as well. Napa has a book with all of these in it for anyone who has as store around them, all of the ones I know of stock these pretty regularily.
Quick Reply: T bolt clamp measurements for IC piping?
