Fidanza or HKS cam gears?
i would go with fidanza because of its 5 bolts pattern vs the 3 bolts of hks.
AEM, vishnu, and fidanza are all very good 5 bolts cam gears. Dont give me wrong hks are good peices as well, but u have more security with the other ones.
ugh...i dont know why you guys spread this speculation..its comes down to cost and personal preference...thats what you should decide on...how often have you guys heard of the hks 3 bolts slip...? 3 bolts is fine...unless youre an idiot and not tq them down correctly...so like i said...COST and PERSONAL PREFERENECE...they both will do the same thing...i like the new look of the hks gears...but thats just me...
If you get fidenza gears, do yourself a favor & replace all the hardware: nuts, washers & button head cap screws with the better quality pieces.
I just did a cam install over the weekend, the retaining nuts where CHEEZY, maybe 3 threads of engagement, thin nuts) & the sprocket retaining screw length's were different from gear to gear.
Outside of that, the gears looked ok.
I have had a sset of Unorthodox Racing cam gears for about a year and I have not complaints at all. I would say it is personal preference. All that you mentioned are fine, I went with UR simply because the tuning shop I go to reccommended them and they were in stock at the time I went to purchase them.
I have pictures of the GREAT fidanza cam gears that cracked and almost cost the motor. I would probably not recommend them
Here is the url:
http://www.vasso.net/cars/showgallery.php?cat=534
You should definately think twice before getting those
Here is the url:
