dynoflash question
Originally Posted by nnorris7413
I have an apexi avc-r and safc II, would it be pointless for me to get a dynoflash, or would it still give me some gains?
Originally Posted by lil'evil_evo
It will help for sure. Using the safc you can have a different tunr for race gas or alky which is a huge benefit.
It has several advantages over the AFC
1 - Timing and fuel are adjusted speerately
2 - Fuel cut and rev limits are also addresed
3 - The flash comes pre tuned for your specific mod combo - in most cases its ready to use as it comes.
Usually we see big gains in low end tq with the flash over the safc and a much smoother power curve
Do a search for more data
i doubt ill be using either of those any time soon.
After reading this, maybe you could clear up this question Al, i know i'm not the only one who has this. If i have a boost controller ( manual or electric ) and a SAFCII, i can control the same stuff as you would with a reflash correct? ( i'm just asking this cuase i know many others will ask ), i mean with that combo you virtually got a reflash correct? can you go into a little more depth as to how they differ and such?
You can't control timing with the AFC II and MBC. You get an increase in power and torque with a flash over the AFC II because he is able to adjust the timing on top of controling fuel and boost.
Every car is different, even with the same parts. With your AFC-II you can tune the car yourself, and dial in settings that are optimal for your car. AFC, plus bigger injectors, and you will have all the timing you need and no fuel cut.
http://www.evotuners.net/forums/showthread.php?t=315
kmartizdatruth
12
Oct 15, 2009 03:25 PM
LIL EVOL
Feb 27, 2007 05:28 AM
MIevo8MR
Midwest Region
Nov 14, 2005 07:20 AM
