GSC Power Division Cams - Installed and turning!!
#61
Originally Posted by yesevo
evotexas , seems like u have alot less torque, is it because of 264 ex?
i think 264in/272ex set up has more torque.
#62
EvoTexas,
Curious as to your ECU map when you had the 264's and the 272/264 GSC cams. Was your ECU map stock for both HKS and GSC cams? I was wondering how safe it would be and how much gains I would get without having to reflash with the 272/264 combo.
Thanks,
slvrevo
Thanks,
slvrevo
#64
Originally Posted by slvrevo
EvoTexas,
Thanks,
slvrevo
Thanks,
slvrevo
I do not have cam gears but I have some on the way. You don't need them, but I just want to play with them and see what happens.
#65
Originally Posted by inariv5573
Yeah, but they are impressive numbers nonetheless. If I had those numbers I could tell others the impressive numbers I was making, regardless of the dyno. Besides I'd rather go on an AWD dynojet anyway. An Evo is not a Mustang, and it is not rear wheel drive.
#68
Originally Posted by redevo561
there has been alot of threads on that topic just do a search bro =)
lol...ive been reading up on it for the past few hours and have heard every opinion under the sun.
#71
Originally Posted by GregGSC
272/272 power-division cams with stock turbo and stock block. Stock ECU reflash
yea could you please post the mods that the car had and what type of gas this was done on to get theese type of numbers, this number is hard for me to swallow without knowing the mods,
I am also considering these cams, just dont know which combo to go with...i want most power yet i dont want any lump idle....decisions decisions....
#72
From what ive read you can get a consistent idle with a good tune. GSC recommends for a daily driver/autox car 272/264. The only thing im still worried about after reading up on these cams is the long term reliability of the valve train. Cam gears are also no needed for the above mentioned setup.
#73
FSU, when you ask about long term reliability of the valve train, are you talking about the GSC cams vs. HKS or do you mean in general? Since they are both designed to use the stock valvetrain what would give you concern? The HKS cams have been around for a long time and people have used them reliably for many years...
#74
The numbers that ive seen have them beating the HKS cams by a good margin and with the same lift/duration. One of the concerns is that GSC is able to do this by having steeper cam lobes which are harsher on the valvesprings, however the detailed specs havent been released yet so this is just an assumption at this point. The other alternative is that they are 'underrated' in terms of lift.
Here is a great thread that discusses these cams...
https://www.evolutionm.net/forums/sh...light=gsc+cams
#75
Bringing back an old thread but from this quote... I plan on eventually putting in a 35r turbo and some 272's, Eventually I will either stroke or at least do pistons and rods. But to get the most out of the car anyway I want to have a higher rev so I would go with Ferrea probably and run 8500-9k redline but does that mean the HKS cams or GSC Cams wouldn't work because of the higher revs/ made for stock valvetrain?
