Help with my stutter problem?
Old Mar 10, 2005 | 01:23 PM
scott88vr6's Avatar
Ok, here is a list of my mods and the problem I am having
AEM intake
Hallman MBC
Walbro 255
3 in TBE
HKS 272 Cams
Ecu Reflash
NGK BPR7ES plugs gapped at .026
Buschur Upper IC pipe
Helix Lower IC pipe
Buschur Intercooler
1G BOV
The problem I am having is between shifts. It seems as if when I am really giving it all its got, I shift and then come bacxk on throttle, the car stumbles for a split second and then the power comes back online. It feels kind of like a misfire, but I checked all the plugs, changed them out and everything and don't have a check engine light. I replaced some vacuum line from the FPR and what not to see if that might have been the problem and it still does it. One thing weird that I realized was that in the mornings while it was cold and my car was still warming up, driving around in a low gear my EGT's would always be aroun 1400-1500 degrees farenheit. The all of a sudden they dropped like 150-200 degrees F from what I was used to. Also I used to be able to hear my Walbro and now I cannot hear the loud whine? Yes the pump is still working. I checked all my electrical connections to the plugs and coils and everything is good there as well. Once again I do not have an SES light or anything. The car pulls really hard, but the minute you downshift or upshift really fast it stumbles for a second. If anyone has any suggestions, let me know.
Old Mar 10, 2005 | 02:52 PM
dohc4g63's Avatar
Lightbulb
You are not venting to the atmosphere are you? if so re-circulate that bish
Old Mar 10, 2005 | 02:55 PM
scott88vr6's Avatar
Nope
Old Mar 10, 2005 | 03:18 PM
EVOTEXAS's Avatar
Speech class.
Old Mar 10, 2005 | 03:54 PM
EVOONYOASS's Avatar
I would suggest doing a boost leak test and check all your fittings to make sure they have not been tightened so tight they cut the coupler maybe. My friend ran into the same problem and thats what it turned out to be. Have you tried a compression test? Ignition wires maybe?
My first guess would be a boost leak because you car stutters when you downshift, thus air is leaking and your getting too much feul and bogging the engine until the turbo spools up more and can eventually somewhat match the feul being delivered. Just a reach though. Good luck.
Old Mar 10, 2005 | 04:58 PM
scott88vr6's Avatar
Anyone else?
Old Mar 10, 2005 | 05:16 PM
EVOONYOASS's Avatar
Originally Posted by scott88vr6
Anyone else?
1. Pump could be taking a poop or not enough voltage.
2. Injectors might need to be cleaned. Do you run alot of leaded race gas?
3. Hole in FMIC, piping, or coupler.
4. Check your throttle cable for binding.(i'm reaching here)
Kinda hard to diagnos your problem over the internet.
Old Mar 10, 2005 | 05:54 PM
scott88vr6's Avatar
Just checked all the piping for leaks and what not, nothing there, took of the FMIC, nothing there, I am going to go for a drive tonight. If it keeps acting up, I am going to throw in my stock pump to see if that might be the problem. Thanks for the suggestions. I will look at the throttle cable as well.....you never know. I put a ground wire back on its intended location, hopefully that may change things? Who knows, wish me luck
Old Mar 10, 2005 | 06:23 PM
mhgsx's Avatar
swap out the plugs.
Old Mar 10, 2005 | 06:28 PM
ezhangin's Avatar
Try taking out the intake, unless your car is tuned for it
Old Mar 10, 2005 | 06:33 PM
scott88vr6's Avatar
Car is tuned for the intake
Plugs have been changed
Old Mar 10, 2005 | 06:55 PM
scott88vr6's Avatar
Just took it for a spin and it still stutters. I don't know what the hell it is now.
I checked everything over?
Old Mar 10, 2005 | 07:51 PM
EVOONYOASS's Avatar
When you say you checked for leaks, do you mean you used a air compresser and it held 25psi steady and you sprayed everything down with soapy water?
Old Mar 12, 2005 | 11:12 PM
fareastkorean's Avatar
i kinda have the same problem, but my car stutters wheenever boost kicks in. No leaks, no nothing, dont know wtf the reason for my car stuttering is. After i got rear ended it started doing it 8- ( Takin it to mitsubishi tuesday, I should change my bov back and put on my cat before i take it in 8- X
Old Mar 13, 2005 | 08:49 AM
scott88vr6's Avatar
After I was done checking everything under the su, I put some good gas in, not the normal 91 pump ****, drove it for a bit and it is all good now. Crappy gas here in Utah.
