Injector duty cycle w/ HKS 272 Cams?
How much should I expect my idc to go up with cams and a tune.
The highest I have hit right now with my mods and running a stock map is 82%
I have tbe, injen intake w/ upper ic piping, cat delete, walbro 255 fuel pump, mbc set to 21 psi, utec, and hks cams(yet to be installed.
Im going to get tuned in april and was wondering if maybe I should upgrade to bigger injectors. What do you think?
Oh and if I run the generic turbo xs map for just a tbe it drops my idc to 76%
Thanks!
--Josh
Thanks!
--Josh
no injectors yet
you dont need injectors unless you upgrade to a bigger turbo! i think Bushur is taking out the injectors out of his stage 4 i think. i have the stock injectors with the following mods and they work fing:
272in/ex
fidanza cam gears -2/-2
pwr intercooler
pwr radiator
walbro 255 lph
AMS lower intercooler pipe
RMR turbo-back exhaust (no cat) off road pipe.
I run mostly 110 leaded in the tank.
exedy triple carbon
xede flash/xede piggy back
call or check with vishnu, they seem to know what is needed when.
good luck!
272in/ex
pwr intercooler
pwr radiator
walbro 255 lph
exedy triple carbon
good luck!
