Tomei Poncam 260 10.7/10.2
i am also looking forward to hear reviews about it. i was wondering if the tomei system2 replacement ecu can be mate with the procams 260IN/EX 11.5mm lift.
This won't tell you everything you want to know, but it should help.
cam specs .
I bought the 260 procams (not installed yet) because I know what lift does over duration and I really like big midrange over the screaming your lungs out on the top.
cam specs .
cam specs .
cam specs .
I know a man who use this cam and and vale spring on evo7, run with stock turbo ( 250 lt/hr. fuel pump ) and controled by Apex Power FC make 380 hp and 50 tq. He said that in 1st-3rd gear it raving and push your back deep into the racaro.
Yes the 260/11.5 Procams are made to run with the Tomei System2 ECU. But you will need to upgrade valvesprings and retainers
I am currently using the above and yes depending on what you wanna build midrange punch is where its at.
I had my stock ECU flown to Japan where it was custom flashed for the cams as well as having the boost/speed/fuel cuts removed.
Incidentally I dun use the ECU anymore as i have moved on to a fully programmable ECU. So if you are looking for a tomeri Series 2 ECU for swap. PM me.
