question on jetcoating the manif.
Old Apr 4, 2005, 11:56 AM
  #91
honki24's Avatar
Originally Posted by mifesto
1.the additional heat that will travel down to the turbo will be minimal considering the heat in the turbo is already up there.... and since i have stock turbo, i dont think my radiator or my IC is max out yet, plenty of cooling margin which will mean insignificant temp increase overall... BUT the reduction of engine bay WILL be quickly felt. in addition to the slight increase in HP gain, it will increase the life of the electrical wiring and other parts from over exposure to heat (starter, battery, wires etc)...
check it out:
Originally Posted by davidbuschur
To be honest, I don't know if the coating will gain anything on spool up or actual HP. I am sure though that you will not loose power. For me the biggest reason to do it was the ignorant design of the hood on the car. It allows water, salt, bird **** and anything else to get in and on the engine. As you all know it takes no time for the manifold and such to look like crap. The coating keeps it looking nice, that is my largest reason for doing/offering it.
David Buschur
www.buschurracing.com
Good enough reason for me to let go of the "well, maybe it will help some" mentality w/ respect to hp/spool. From the man, himself.
Old Apr 4, 2005, 12:16 PM
  #92
David Buschur's Avatar
The only 10.5's are the MR's they are $600 ported, that is all we have. Yes, we can port YOUR parts and would prefer to do that, $100 each for porting. $125 for each coating.
David Buschur
Old Apr 4, 2005, 01:10 PM
  #93
yesevo's Avatar
who is gonna port and coat it? dave or u send it out to someone who does that?
i want quality job.
and which one u recommend? port only or combo
Old Apr 4, 2005, 05:22 PM
  #94
honki24's Avatar
hey Dave, so If I send you my non-MR 9.8 as well as my manifold, will the 9.8 end out like 10.5? or only slightly larger than 9.8? And if it is only slightly larger, are the gains like the 10.5?
Old Apr 5, 2005, 07:10 AM
  #95
yesevo's Avatar
do u coat on heat shield?
the one buschur sells is stainless?
Old Apr 5, 2005, 08:48 AM
  #96
We do all the porting here and then we ship it out to have ceramic coated.
We only port match the turbine housings to the gaskets, it is impossible to convert a 9.8 to a 10.5 by porting it.
Yes, I could coat the heat shield but to be honest it would still be ugly and cost more than just buying our stainless one.
David Buschur
Old Apr 5, 2005, 02:48 PM
  #97
honki24's Avatar
I'm sorry that this is and I'm jacking my own thread, but while I've got your attention Dave... sir, could you help me with my current frustration? I just tried to eliminate the use of the ac compressor by using a smaller belt. I looked on this site, and found that someone suggested a 560k6 from local parts store, and Al endorsed it, so I went out and tried, the belt is aboooouuut 1-2 inches too short, I tried with all my might. I also tried their other closest sizes (595 and 538) of course too big too small, respectively. Now I have also seen on here that Al reccomends some "gate" belt, I looked it up and I'd have to go a good little distance to get one, so will THIS one fit??? have YOU ever done this Dave?? any suggestions??
Attn general audience: This is simply a request for info from an expert, so please no responses such as "why would you want to do that?" or "you know, if you take the belt off the compressor, the compressor will deteriorate without usage." However if any of you have done this successfully w/o purchasing a pricey belt from then please enlighten me on my foolish ways. Thank you so much.
Old Apr 5, 2005, 08:13 PM
  #98
yesevo's Avatar
i thought u port whole area inside...
Old Apr 6, 2005, 09:33 AM
  #99
honki24's Avatar
also, aprox. how much is ported off? (I don't know the gasket size)
HR2L
Apr 11, 2011 05:31 PM
Dragking2189
Jan 16, 2011 01:26 AM
Nastynine
35
Aug 20, 2009 08:30 AM
deadbeatrec
49
Jun 4, 2007 08:36 AM
EVO8LTW
37
Mar 31, 2005 07:45 PM
Quick Reply: question on jetcoating the manif.
