Has anyone overheated a Walbro fuel pump yet?
Twice now I've had the car "die" after prolonged cruising at 70-80mph. After waiting a few minutes, it starts right back up as if nothing were wrong, and runs fine. I don't recall if I heard the pump cycle or not at the time (it was 3:30am and much too late for this old man to function). It is an old pump that has seen 90-100psi while serving a SC GSR with a boost dependent regulator... so I'm ordering a new pump this morning. I have seen a similar problem in the Honda camp, but that was a long time ago. However, I'd like to know if anyone has "wore out" a Walbro in an Evo yet. I don't like "unanswered questions" even if I find a solution.
Interesting. I took mine on a non-stop drive to and from Wyoming-Texas (1150 miles) and never experienced such a thing. That trip included a few good 4th gear pulls and lots of 90-95mph cruising.
I just took my EVO on a Phoenix-Denver trip and stopped only for gas and never had a problem with my Walbro pump going wacko. I just installed it the night before I went on my drive.
Originally Posted by Zeus
Well, switched out the pump... no good. I'm thinking a relay is dead somewhere. I just don't hear the pump prime when I turn the ignition to the "on position".
BY the way, the Evo fuel pump only primes when cranking, not with the key on like most other cars.
Like someone else asked, did the car just fall flat on its face or did it start to sputter then slowly cut off? If it was sudden then it could be an ignition concern. A bad or weak FP will slowly come to a stall. You may also want to check the injector harness and ECU harness, a bad connection will cause a loss of signal to the injectors or coils. Did you recently have any part of the engine apart? Like a the head?
Another pump was swapped in... resistance on the coils is good. There is spark at the plugs while cranking. I pulled the fuel return line and cranked it over... no fuel spurting everywhere (in a bottle)... zero. Started checking relays. The #1 #2 under the dash were fine. Pulled the #3 off the fire wall and had no continuity between #1 & #2 pin (if I'm holding the damn relay in the correct position) as there should be per service manual 13A-768. Pin #3 & #4 had continuity as they should. I think I found my culprit.
Thanks to everyone who posted... until I get another #3 relay on the car, I still consider this matter open as my new relay will not get here until Monday. I'm going to try to borrow one before then just to "make sure that is the issue".
