Lifter cleaning tips, tricks
Old Mar 17, 2005, 07:34 AM
dryad001's Avatar
Well the lifters are just making too much noise for me, I can actually hear them over the radio. So they are coming out and getting cleaned. Anyone have a easy way to clean them. I heard diesel fuel works.
Old Mar 17, 2005, 07:35 AM
93civEJ1's Avatar
i really think you are gonna waste your time, and it will be back in no time.
Old Mar 17, 2005, 07:38 AM
electricevo's Avatar
umm, cleaning the lifters is not going to do much but waste a lot of time. the only reson why that noise is so pronounces from inside the car is that the hood has no sound deadening material on it. so if you want, do that but it'll add weight...
Old Mar 17, 2005, 08:09 AM
dryad001's Avatar
So your saying I just have to live with the lifter tick
Old Mar 17, 2005, 09:06 AM
4G63>OOOO's Avatar
Or you could run the car at 140+ for about 5 minutes or so, that cleans them out pretty well.
Old Mar 17, 2005, 09:51 AM
ExViTermini's Avatar
did that the other day and they still make noise....I think its just a typical OHC thing, most honda's do it as well, only worse.
Old Mar 17, 2005, 11:17 AM
dohcvtec's Avatar
you can check your valve lash, i'm sure it just needs to be adjusted. yes, honda dohc motors do this too.
Old Mar 17, 2005, 11:21 AM
cruizinmax's Avatar
It is not adjustable on the 4g63. They adjust automaticly
Old Mar 17, 2005, 11:26 AM
housedj's Avatar
Thumbs up
if you're gonna do all that, you might as well get ARP head bolts, Ti retainers & lift springs while you're in there. they will only help your cams work better & then you can rev safely to 9K...
Old Mar 17, 2005, 02:38 PM
dohcvtec's Avatar
ah, didn't know that! thats good, i hate doing the lash on my honda.
Old Mar 17, 2005, 06:19 PM
dryad001's Avatar
I end up doing all that along with solid lifters. But before I do, the GT30R turbo is going on along with injectors and a clutch, mild tuning then back to the head.
Old Mar 17, 2005, 06:52 PM
superz's Avatar
YOu think you have a tick now, wait until you go with solid lifters By the way, properly installed cams will never tick Proper bleeding of the lifters prevents the seals inside the lifters from rupturing. In other words dont use the same shop for your future work, and if you did them then you should use a good shop
Old Mar 17, 2005, 07:09 PM
dryad001's Avatar
The tick wasn't always there. I have had my cams in for about 4 months. The tick started about 3 weeks ago. I'm guessing that I would either have to replace the lifters or re-bleed them. It seems that it is coming from Cyl 1 or 2 and is 1 or 2 lifters that are making the noise. But the tick goes away once the engine passes 3000rpm.
Old Mar 17, 2005, 07:17 PM
marksae's Avatar
dryad001, what oil are you using BTW?
Old Mar 17, 2005, 08:11 PM
dryad001's Avatar
Mobil 1 10w30. Switching to Motul in the summer
Quick Reply: Lifter cleaning tips, tricks
