412 tq (stock turbo) on 93 pump gas with Dyno Flash and Alcohol kit
#34
Originally Posted by FlyNavy
I'm installing your kit next week with similar mods already. How much power would he or I lose by using wiper fluid vice straight alky? My car made 366 on 94. I'd like to get close to 400 on 92. Doable on washer fluid?
My prediction is that 50 / 50% h20 and denatured alcohol will make almost the same power as staight alcohol - but testing is how I like to proceed
#35
Originally Posted by NOLIMITMOTORS
any way I can get a bolt on kit for my 2005 evo?
#39
Originally Posted by cHuCkUfArLiE
Well on the Turbo Trix site Evo-Doer made more HP than your busher equipped methanol injected car did on Race gas. Personally I'd rather go that route.
Also - comaprin these two cars is like comparing apples and oranges
Here is teh TT dyno sheet with $2,000 aem system on RACE gas
Note that despite the fact that its on race gas with no MAF sensor the tq is less and the power curve falls off up top. Also this guy is on 280 cams while my customer has 264
Here is the pump gas dyno sheet
Any my customer's sheet with pump gas, alcohol and STOCK MAF sensor
I am not saying that the TT tune is bad - in fact is good. I am just refuting your simplistic staement - he made more power. In fact - even though the meak # was sligtly higher at spool up there is more tq on my customer's car and more power and tq at 7,000 rpms also. - A more broad and even power band equals a faster car.
#40
WOW!
Al, I take it I should be getting the same type of output. You tuned my car at Buschur back in Feb.
Stage 1-4
272's
680 inject
alky (denatured) set to start at 17psi and max out at 22psi. Should I set it up different?
Turbo hits 23psi and tappers to 20-21.
I'll be taking her to the track on Saturday to see what she'll do . April 30 I'm going to put her on a dyno pack and see what #'s will come up.
Stage 1-4
272's
680 inject
#42
The Turbo Trix car does not have any of these add on parts
I disagree:660cc Injectors,FMIC,IC Pipes, The TT car made more power, and torque without these components, They even had the Stock air box Wow!<This is what I can see. Torque moves you, HP is what you need on top. Both are strong, but Id rather have a HP car than a alcohol car. If the TT car installed the components that are in the busher car, Those #s would be increased too. The TT car made great #s for having hardly any additions is what i'm saying. I like that very much. Also the TT car made more HP, and similar torque than your alcohol/pump tune. That is Apples to apples. That car runs strong with out any power assistants. Very cool.
EVO VIII UPGRADE SEQUENCE
STAGE 4 In Stage 3 we were able to achieve our best numbers at 19-20 psi on pump gas before we hit fuel cut. In order to work our way around the fuel cut issue with the stock ecu and Super AFC2, we installed larger 660cc injectors and a 255 lph fuel pump. Utilizing race fuel, we were able to retune the car for a peak boost of 24psi which would immediately settle to 20-21 psi due to the limitations of the stock turbocharger's compressor wheel. Although we were still able to increase the peak horsepower (now up to 380.8 whp), the torque increase was substantial to say the least. Previous best torque was 303.9 ft/lbs in Stage 3, but has increased to 349.1 ft/lbs @ 4500 rpm as measured at the wheels!
CLICK TO ENLARGE1/4 MILE PERFORMANCE OF BR EVO VIII WITH BUSCHUR RACING STAGE 4 PKG:
60FT -
1/8 ET-
1/8 MPH-
1/4 ET-
1/4 MPH-
CLICK TO ENLARGEStage 4 package as tuned with the Buschur Racing Flash Tuned ECU. This dyno chart was produced utilizing race gas and higher boost. Run 70 shows the result of higher peak boost. This run produced higher peak performance, however the heat generated by working the turbo that hard sacrificed some high end output. Run 72 shows a little more conservative tuning and is the run our Stage 4 ECU flash is based on. As with any of our flashes, you can use the SAFCII to fine tune the a/f ratio to your particular needs. AS TESTED:
FUEL - RACEGAS
BOOST - 24 PSI PEAK, SETTLING TO 20-21 PSI
BOOST CONTROL - BR MANUAL BOOST CONTROL
INTERNAL ENGINE MODIFICATIONS - HKS 264 INTAKE AND 264 EXHAUST CAMSHAFTS
TURBO MODIFICATIONS - NONE
INTERCOOLER - BR FRONT MOUNT INTERCOOLER KIT
INTAKE MODIFICATIONS - BR AIR FILTER KIT, BR UPPER I/C PIPE KIT, BR MAF PIPE KIT, BR BATTERY KIT
EXHAUST MODIFICATIONS - BR 3" FULL EXHAUST
CATALYTIC CONVERTER - NONE
ECU MODIFICATIONS - NONE (BUSCHUR RACING ECU FLASH AVAILABLE)
FUEL TUNING MODIFICATIONS - SUPER AFC w/BR CALIBRATION (STAGE 4 SPECIFIC SETTINGS)
FUEL DELIVERY MODIFICATIONS - 255LPH FUEL PUMP, 660CC INJECTORS
60FT -
1/8 ET-
1/8 MPH-
1/4 ET-
1/4 MPH-
FUEL - RACEGAS
#43
im impressed with the amount of power these 4g63's are making with this little of modification.
i just wanted to point somthing out becasue im really not sure if everyone is aware of this. alcohol/water injection cools down the charged air/throttle body/intake. it really dosn't provide more power. it just reduces the knock sums in your ecu and alows for better timming advance. it really works the same way as n02. there are diffrent kits. some you spray in your intercooler to prevent heat soak, some you put interveinsly, some even for the turbo itself. they all work for the same thing. to pack more, cooler air/fuel into the quench before detination without any pre-detination.
#44
#45
Its funny how thing always end up?Sad that they all ended the summer the same way,looking for a rebuild.
