is my head gasket gone or head cracked?
yesterday was driving the car doing about 120km/h consistently for about half an hr......everything on the inside was fine....air/fuel,temp etc.
then the car started to misfire....and then started to sound like if the coils were messed up...
so i pulled across and popped the hood.....the idle was rough. got back in the car to realise that the temp gauge had shot up...nearly got to the top!
got the car wrecked to be on the safe side.....checked it today...everything llooks fine.....water/oil...everything is good.
started it but it keeps doing the same thing.....btw..changed plugs about 2 days ago!
any help...
any help...
Originally Posted by SLVROZ_03
Well, like you said you changed the plugs a couple days ago... That just might be the problem. Good luck with the troubleshooting.
You would not necessarily get a CEL for misfiring plugs. Just check the gap and make them .026. Also, what plugs did you put in? That can make a huge difference. If there is no oil in your coolant then it's not your head gasket. However, something is up with the high temps.....
Originally Posted by 11secEVO7
umm they are denso's IW28 i think....
I'll check the gap...thing is...i used these plugs before.
yeah the IW28's re supposed to be 11's
I use this because I use nitrous and it's recommended that I use colder plugs.
Thing is I have used these plugs before....they lasted for months of racing.......had no issues with them.
Hey,
anwser these questions and i will try to help you out.
what does your oil look like, is their milky white on your oil cap or on your dip stick? you are looking for water in your coolant.
what does your coolant look like? you are looking for oil in your coolant
what are your compression numbers? cold and hot please.
what are the results of your leakdown test?
what do your spark plugs look like? pics will help.
If the temp gauge shot up all the way to the top, i would be worried about warping the heads/bolts and other parts. I have no idea why the temp would go up for misfiring/detonation. Doesn't quite make sense.
