To those with Tial wastegate and Profec B spec II
I just installed my custom turbo kit yesterday and have run into a problem hooking up the tial wastegate and profec b. I have tried running the com port on the solenoid to both of the nipples on the tial but it is still overboosting. Any help would be appreciated. Here are some pics of my new setup. Thanks in advance.
only use the nipple that is on the side of the wastegate not the one on the top...the top one will allow the turbo to spool to its max.
http://www.enilson.com/evom/AndrewTu...r/install4.jpg
it goes from wastegate(side nipple) -> turbo ....then u tap into that line w/ ur boost controller.
