Low Dyno Numbers
Low Dyno Numbers
Yesterday I had my car dyno'd for the first time. I was pretty excited because I figured I would get pretty good results. We did about 6 pulls on a Dynapack, which is probably the most accurate results you can get on a dyno. Anyways my two highest pulls were 236 and 238 awhp with 261 and 263 torque. My mods are in my sig and this is what was dyno'd.
I was hoping for numbers in the range anywhere between 270 - 290ish for awhp. Currently I'm boosting to about 20.5 PSI and tapering to about 17-18 PSI near redline. I'm pretty sure I don't have any boost leaks and the car is running and sounds great.
I don't have any baseline runs before I added all my mods so I have no idea what kind of gains I got from my mods. The only way that I can compare to see if I got any gains is from my 1/4 mile times. When I was stock I was averaging about a 14.2 with a 2.1 60ft. After I got my intake, mbc @19PSI, and catback I was running 13.8-13.7 with a 1.9 60ft. I haven't been back to the track yet since I added the EVO MR DV, the BR 3" downpipe w/high flow cat, Walbro, and Dynoflash so I don't know how much this will improve my times yet until this weekend when I go.
It's just odd to me that my dyno numbers were so low. My awhp is what a stocker is around. Maybe I'm just one of those unfortunate EVO owners that got a bad egg as far as producing power? Just wanted to know what you all thought and maybe provide some feedback on why the numbers were on the low side. Thanks.
my numbers are below and i have similar mods. I was on a mustang dyno. I wouldn't fret too much about the numbers. Dyno's are just tools for tuning. It's too hard to compare your numbers vs everybody elses numbers.
Post up the dyno sheet and lets see how the car is running by the shape of the curve , a/f and boost
BTW - just as an aside - 17 - 18 psi at red line is TOO LOW
I have a lt of customers who are holding low boost levels whop complain about low power readings.
ALL of my tunes are claibrated with the HALLMAN PRO MBC which when the car is set up [properly with no boost leaks will hold a peak or 20.5 - 21 psi and 19 psi or more all the way to red line.
Using a sub par MBC which is dropping 3 - 4 psi to red line is loosing youy a lot of power
I would be willing to ship you a Hallman ProMBC to try out free of charge to see if that picks up your top end power
Originally Posted by DynoFlash
First of all - the most important factor for me is the shape of the curve not the numbers - especially on a dyno pak dyno which has so many variables which can be set by the end user which can manipulate the numbers
-Jeff Toevs
Also I have the Hallman Pro on my car and it holds boost solid all the way to redline! You should really try it and see the difference. 4 pounds is a pretty big drop off.
Oh the numbers don't bother me too much. I'm more interested in the gains that I get from the money I put into it. I just wish I would have gotten baseline figures before I started to mod.
As your tq is MUCH higher thanwhp and your booost is falling down to 17 psi - this is why I recomend you try the Hallman Pro MBC which I am willing to send you for free to test. The Perrin has not worked well in most cars.
1 or 2 psi of boost can make a huge difference in the power levels at 5500 - 6500 rpms
Sorry about the low numbers. I threw down 70 more horsepower then you on the same dyno at only 17.5psi (thanks to my peice of crap Defi). I have a XEDE and cams though. PDXEvo is at 306hp on that dyno and he has the same basic mods as you, but he has a test pipe. We are also running the stock air box too.
Wait wait... you're not interested in the numbers, but are interested in the gains that you get from the money you spent? Isn’t that an oxymoron? If I knew that I had put around $2,000 worth of performance upgrades into my car and I did not make much more than a stock EVO, then I would be a bit pissed. I think it would be best for you to find another dyno and get a second opinion. I would also make sure that you car is running right and take Al up on the offer for the Hallman. Al uses and tunes for the Hallman's so you know they are going to work for your particular flash.
Also, don’t DynoPacks read a bit higher than Dynojets because they do not have the rotational weight and friction of the wheels?
I agree with the sentiments above that your numbers especially on a dynapack seem superlow. I've seen friends run on a dynapack with less mods than you've described in your sig pushing 265hp/270torque and 275hp/305torque respectively.
I would put in the MBC that Al is sending you and try a different dyno. I believe dynapacks can be setup differently from dyno to dyno and therefore can put up a wide-range of numbers.
