fuel pressure
phhhhhh, way over my head... or wait:
if you take the old one as 100% and see the difference in percentage to 680cc, that could be the percentage that you need to lower pressure by.
This could be fully wrong, but I think it's a linear formula, if I remember correctly from my school days.... don't want to look in my Physics formula book... too many bad memories...
std injectors 560cc/min your larger ones are 680cc/min.
pressure drop is proportional to velocity (flow through fixed size pipe) squared.
hence if flowrate is increased through larger injectors by 21% then you will need to drop pressure 47% to maintain the same flowrate as through the smaller injectors.
probably
I would suggest getting a decent lambda sensor and a rolling road to set it up properly.
probably
