EGT probe in DP?
EGT probe in DP?
The EGT probe on my VDO gauge is too large to tap into a runner. I was wondering if it would be OK to tap into the DP, and if anyone knew about how much of a temp difference there will be from the DP to right off the head. Thanks.
You may have the wrong probe. The VDO 1/4" npt fitting should work fine on the exhaust manifold. Install instructions for VDO EGT probe.
Evomoto has install instructions for the Defi probe that does not require removal of manifold. They will also work for VDO probe.
Nope, it's the VDO probe, I even purchased it from 42 Draft Designs.
My friend swears by EGT gauges, but considering I'm on the stock turbo and ECU I doubt it will be that big of an asset.
I may sell it and go with a oil temp gauge.
I currently have boost/oil press/egt.
