Best way to achieve 375-400whp on stock turbo?
Old Apr 27, 2005 | 02:37 PM
NocturnalEVO's Avatar
Originally Posted by wEstSidE
You also said something about constant power on tap, which I don't quite understand. If you did alcohol injection, the power would be there when you want it. Same with race gas.
I'm sorry, i thought alcohol injection worked like nitrous, where if you push the nitrous button then you'd get the extra boost.
I gotta look into the alcohol injection more hehe.
Old Apr 27, 2005 | 02:43 PM
After reading how much that guy with the 600+whp Evo spent, i think i might have to wait a lot longer on that AMS turbo upgrade lol..
I think for now i'm going to get.. (just thinking for now)
- buschur fmic (already on order)
- UTEC or AEM EMS (but like Jack says, i won't pass inspection, that will be a problem).
- Bigger injectors
- 10.5cm hotside
- ported tb
- and maybe alcohol injection
Old Apr 27, 2005 | 02:46 PM
on a side note, do you guys think a stroker kit with the stock turbo will help at all? I mean i will get a turbo upgrade down the road, but will i be able to use a stroker kit in the mean time with no problems or issues?
I've read that going with a stroker kit gives u a lot more torque. But most of the guys i've read about that have it, have a turbo upgrade too. That's why i'm wondering..
Old Apr 27, 2005 | 03:08 PM
ninjadoc's Avatar
Call Alamo in TX 817-860-4300 for a TME turbo. Ask for Brice and he'll hook you up on a TME turbo.
Originally Posted by illegalakkord
Oh yea i forgot about injectors.
I will be getting the denso/greddy injectors (660cc i guess?)
Soon2BEVO:
Where can I get the 10.5 Turbine housing? and how much do they go for?
rlazer5000: i would prefer to stay away from the alky injection because i want constant power thats on tap at all times, ya kno?
About the TME turbo you mentioned, where can I get one? and how much do they go for?
I am planning on getting a full AMS turbo upgrade kit next year, so I don't wanna do nothing TOO drastic right now, ya kno? All the parts that i'm getting right now I hope will save me from buying parts later with the turbo upgrade kit. So i want these parts to work with the future turbo upgrade
Old Apr 27, 2005 | 05:59 PM
thanks
Old Apr 27, 2005 | 06:04 PM
Kbp2025's Avatar
Just hang with as many stock parts as long as you can to keep your waranty. Just a thought... But if you do break it, definately postpostpost!!!!!!
Old Apr 27, 2005 | 06:06 PM
haha my warranty's long gone...
Old Apr 27, 2005 | 07:14 PM
Bom's Evo's Avatar
10.5 hotside &
More boost with ALKY Injection!
some bigger injectors.
Old Apr 27, 2005 | 07:26 PM
ninjadoc's Avatar
They are back ordered for a month or more. The only place i found one in stock was at forced performance or alamo autosports in Dallas.
Originally Posted by rlazer5000
Actually u can find the the TME Turbo at Buschur racing for $975 ( http://www.buschurracing.com/cgi-bin....cgi?27X376545 ), but it might be cheaper if u give them a good core (dont quote me on this). But if u plan on getting a AMS turbo upgrade, then just wait for that! Save up some serious bank and go all out! I really want an AMS upgrade, but i dont have the money (im a poor college kid). AMS will definitely hook u up! Good luck bro!
Old Apr 27, 2005 | 10:58 PM
What about a tubular manifold? how much of a gain will that give me?
Old Apr 28, 2005 | 07:50 AM
rlazer5000's Avatar
I couldn't tell u how much a tubular manifold will help, but i thought u said u were getting an AMS turbo kit? Their manifold is a piece of heaven......just try to save up for that rather than blow money of stuff your gonna replace later on. As for the stroker kit with the stock turbo, basically the turbo will spool up a couple hundred RPMs sooner and they're will be about a 15% increase in torque (according to AMS). If u wanna take full advantage of the GT35, then a stroker kit is definitely gonna help. But if your getting a GT3071 or GT3076, you'll want to stay with the stock 2.0L, but maybe think about strengthening the internals.
Old Apr 28, 2005 | 09:46 AM
I will get the AMS turbo kit, i'd like to go with the GT35 but it's gonna be a whole lot more $$ than I expected. So that definatley isn't coming any time soon.
Old Apr 28, 2005 | 10:19 AM
EVOMIZ's Avatar
your gonna have to get every little bolt on to come near that number, throttle body, crank pulley, a little port here and there, AEM, 280 cams, pump injectors, pump, 10.5 turbo allkey kit, fmic,spark upgrade, and up the boost (24psi @ min) and some aggresive map tuning.
some of these parts are over kill but will need them later anyways when you run the ams kit (AEM, spark upgrade)
Old Apr 28, 2005 | 10:32 AM
03BREvo8's Avatar
a Buddy of mine was at Pruven and saw 2 evos with stock turbos dyno 400+ no juice... if your running the stock turbo you DO NOT NEED Bigger injectors... A flash will take care of the fuel cut.. stock flow 550cc so there fine for the stock turbo... With Alc you should easily hit 400... you can run 26psi on the stock turbo with the injection kit....
Old Apr 28, 2005 | 10:34 AM
Z1 Performance's Avatar
again, stock injectors won't come close to cutting it.....
