guys w/ aftermarket cams, what is your idling vacuum
Old Apr 26, 2005, 05:08 AM
Evofurry's Avatar
13 with 272's
Old Apr 26, 2005, 06:25 AM
berkel's Avatar
Hi,
Solid 18 inHG with stock cams.
Now solid 15 inHG with Buddy Club 264i/272e, stock cam gears, custom dynoflash.
I have a slight lope, not sure it will pass emissions... I saw that someone with 264/272 and cam gears got the idle upto 17 inHG. Does "higher" vacuum mean a cleaner idle? It would seem so. I guess I can get cam gears if I have problems.
Thanks,
FB
Old Apr 26, 2005, 06:46 AM
Ted B's Avatar
30cm Hg or 11.8" Hg with HKS 280s - better than some others with smaller cams.
Old Apr 26, 2005, 07:03 AM
Event-Horizon's Avatar
-.47 bar on 272/264's
Old Apr 27, 2005, 02:28 AM
GREDDY's Avatar
-.4 bar with 264/272. Idles like stock 800-840rpms.
Old Apr 27, 2005, 03:36 AM
EVO8LTW's Avatar
18 stock
15 HKS 264/272 at 0/0 (closed loop)
Old Apr 27, 2005, 07:29 AM
Stinkapuss's Avatar
15 inhg with HKS 264's
Old May 4, 2005, 06:44 AM
SterlingEvo's Avatar
12-13 inhg 272s
Old May 4, 2005, 03:53 PM
JustDSM's Avatar
12-13in/Hg on 272/272 (-4/-1) at 6100ft ASL.
Old May 4, 2005, 07:38 PM
1.8t's Avatar
Am I the only person to be pulling 20" w/ stock cams??? I will let you know what my vac is after my GSC 272/264 setup goes in.
Old May 5, 2005, 05:55 AM
PPI
PPI's Avatar
you should of asked if people have raised their idle at all....which is common to help smooth things out. I have 272's with 15in/hg but I did raise the idle about 100rpm over stock.
Old May 5, 2005, 06:04 AM
wingless's Avatar
-.5 ~ -.6 bar manifold pressure with 264's and a Works p2 flash.
Old May 5, 2005, 08:16 AM
Ev0 1's Avatar
13-15in/hg GSC's 272/264
Old May 5, 2005, 01:00 PM
Soon2BEVO's Avatar
16 Hg with HKS 272/272
Stock was around 23 Hg
Old May 5, 2005, 02:51 PM
Turbo13's Avatar
16 ish highway. 12 at idle.
Quick Reply: guys w/ aftermarket cams, what is your idling vacuum
