What turbo mainfold is this?
What turbo manifold is this?
Anyone know makes it or has this turbo manifold? I do not care if you think it sucks cause its only $300, keep personnel comments to yourself unless you have owned this particular manifold and have had problems with it.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
I don't see how that manifold would work for an aftermarket turbo either. The flange is to far away from the stock location. There is no way you could make a "some what" straight O2 housing that wouldn't hit the A/C. $300 is dirt cheap though.
Quality of the materials and the welds aside, there seems to be a problem with the 5th runner for the wastegate.
The current positioning of the 5th runner would put the dump tube right past the compressor of the turbo. The AMS, Full-Race or RNR manifolds all have their wastegate on the other side. There is probably a good chance that the wastegate will come pretty close to the radiator hoses and the fan too.
Either way, this manifold won't work w/o serious steel fabrication.
