Transfer Case Fluid Capacity Issue
I just changed the fluid in my Transfer case and when refilling the TC the fluid would come back out the fill hole prior to getting the .58 Quarts into the TC. (The owner's manual states capacity is .58 Quart) (The car was on level ground)
I even took the car for a spin afterward and rechecked the TC and the fluid still came out of the fill hole, meaning it is full. I just want to know if anyone else has experienced this.
Originally Posted by EvoHung
yeah that happened to me when i installed my TRE transfer case. Juss force the rest of it in there, thats Jons advice to me.
The factory shop manual claims it will hold .63 quarts so try to get that in there.
Jon@teamrip.com
http://www.teamrip.com/Evolution.html
Thanks Hung and Jon, I created a plug for the hose on my gear oil pump so that the hose goes into the TS and plug blocks the backflow from the filler hole, I'm gonna check it again after a cruise to see if it flows out the filler hole, to ensure it is full, I covered my exhaust manifold with a rag when doing this fluid change to ensure the stinky crap didn't get all over the manifold, gotta love gear oil!
Originally Posted by mike 99gsx
Could they have designed a more stupid place to fill that damn oil?!?!? What a PITA that was.
Jon@teamrip.com
Originally Posted by omarv6
guy i just wana ask somthing here..
i changed my TC 2 weeks ago ..it came with the flued in it ...to i need to change it now ..or i can drive on it ?
Jon@TRE
i was so shocked ...it came with seals ...and it was top to the end ..my workshop guy tryed to fill more but it was going out !!!
the tc came in a wood box ...and it was seald from each whole !!! i just told him to change it any way ...and he did today.
he but in about 1 liter in it !!!!! dont tell me how !!!!
maby are specs are diffrent ....cuse what he got out was brand new golden oil wich i saw !! it was about a liter !!!
any way it didnt accept much at first but he rotated the wheels so the gears would take the oil and expell the air ..then add more and more ....he said thats the way to do it !!
well i guess he knows better cuse he said thats thy way the do it for the AWD new lambos morcelagos ...whell this work shop are mainly for fixing lambos and ferraries ..
and the oil thy used was castrol somting ...for transmition and gears !!! thy say its thy same used on the morcilago TC !!!
let me see if i can find it on the net
ok this is the oil he used !!
i hope its ok ....
http://www.castrol.com/castrol/produ...tentId=6004023
i hope its ok ....
Originally Posted by 03BREvo8
hmm tranny case holds 3 lt and the diffs hold .58... it wont make a diff if you cant get all .58 in there..
Jon@teamrip.com
