Koyo radiator and no antifreeze
Is it safe to run the Koyo radiator with straight water and no antifreeze since it is aluminum, in non-freezing weather of course. Maybe with distilled water? With aluminum and pure water rusting and impurity build up should not be a problem. Correct?
although water in pure state is the best form of "coolant" it doesnt help lubercate the water pump the best thing to do is run 50/50 water coolant. also something to think about is Engine Ice. i use it in my motorcycle and it runs much cooler now. it isnt the cheepest thing on earth but definatly a good product. and its enviromentaly friendly for all the tree huggers
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
engine coolant does 2 things. The ethylene/propylene glycol in there increases the boiling point of water and also lowers the freezing point of water. And there is corrosion inhibitors in there to help prevent corrosion.
btw the corrosion inhibitors in the coolant is for the parts containing iron...water pump...housing...aluminum is pretty corrosion resistant because of the protective oxide layer
The cooling system is under pressure which is where most of your resistance to boilover is coming from. Pure water at 13 PSI boils at 255F where as a 50/50 mix is around 265F and honestly if your cooling system is that high you need to increase heat disipation from your radiator with fans and airflow, or put less heat into the system. Pure water along with water wetter will allow the system to absorb the most heat in the engine passages and release the most while traveling through the radiator. This is why some people use higher pressure radiator caps as moving from 13 PSI to 16 PSI raises the boiling point a few degrees and it also helps transfer heat form the head better. Of course you will also stress the rest of the system with more pressure and the weakest hose will burst at the absolute worst time so make sure everything is in perfect shape. 50/50 with water wetter is the best combo for the colder climates where as adding more water ratio to the mix in warmer climates will improve the efficiency of your cooling system. Using 90 water/10 antifreeze + water wetter is as high as you want to go for any long time period for a street driven car as you want some corrosion protection and water pump lubrication in your system. Usually I run 70 water / 30 antifreeze and switch to 50/50 in the winter months but realize that forgetting to change it can leave you a nasty suprise if it gets really cold where you live.
