intercooler spray..
i know of most people using just plain ol washer fluid... during the summer you could use some ice water.. ... Me i use methanol.. only because its not and i/c sprayer anymore... smc alc/H2o injection...
Antifreeze is the worst thing anyone could put in the IC sprayer.
The purpose of the IC spray fluid is to evaporate and remove heat upon evaporation. A mix of methanol and water is ideally suited for this purpose, and since the composition of washer fluid is exactly this, it is recommended as IC sprayer fluid.
distilled water/with methanol mixed ...not sure if there is a low level light for the reservoir ...if there is ..straight alchy will effect it ...a mix of distilled water/alchol will net u some ponies ...just with washer fluid alone evo's dyno'd with it on and off ...showed a 10hp increase ...with it spraying ...so imagine when u put that mix on it...cool taht charge even more ...every little helps ...lower intake temps are the goals...
