idle problems! *help! please!!!
Old May 9, 2005, 03:18 PM
  #31
EvoG8r's Avatar
I've been told that this knocking sound is common on 4G63 motors at low idle. I could be wrong. Mine does it when the idle dips real low too.
Old May 9, 2005, 03:21 PM
  #32
ultraflip's Avatar
thanks g8r...
i caught up with a buddy during lunch... he has the same set up as well.. he somewhat had the knock... but not quite as loud as mine... it has been brought up that i'm just being too **** about the new mods to the car...
then again... that doesn't explain the idle dipping like that
Old May 9, 2005, 04:04 PM
  #33
evillution's Avatar
well i cant compare with anyone else around me no one has mods like me but as for changeing the bov it help my idle a lot! as for the knocking they say it is common and ive asked and yea i got the whole **** remark just like you
Old May 10, 2005, 07:40 AM
  #34
ultraflip's Avatar
so i pryed off the valve cover last night... (don't plan on doing it again any time soon)...
everything seemed in place... everything was in line... everything lined up TDC... *confused*
Old May 10, 2005, 09:51 AM
  #35
timzcat's Avatar
Did you check all the lifters to see if you could compress them?
Old May 10, 2005, 10:02 AM
  #36
NYREDEVO's Avatar
Two things....the tick in the 4G63 is very common. I had it in my 98 GSX and I have it on my Evo.
I also get the idle dip when I slam my hood, but only for a second. Timcatz u said that could be a bad MAF sensor? I have an intake now, i dont remeber if it did it before or not. It doesnt seem to affect drivabilty - sorry for jacking the thread.
Correct me if Im wrong but don't the cams usually do this? Maybe I missed it...but are you flashed or anything like thaT?
Old May 10, 2005, 10:16 AM
  #37
ultraflip's Avatar
pushed the ball down on every one... no problem...
my idle dips during hard braking... dips down to around 500rpms....
could it be a BOV adjustment?
Old May 10, 2005, 10:23 AM
  #38
03BREvo8's Avatar
Wow.. theres no normal reason it should do that.. mine falls faster due to the 10lb flywheel but not below 900rpm
  #39
ultraflip's Avatar
Old May 10, 2005, 10:37 AM
  #40
03BREvo8's Avatar
hows the MAF sensor and the TPS... damaged?
Old May 10, 2005, 10:40 AM
  #41
jj_008's Avatar
If you have an adjustable BOV, loosen up the spring tension.
Old May 10, 2005, 12:34 PM
  #42
ultraflip's Avatar
how do you verify if the MAF is still good?
looking at the honey comb? no bends...
their's a slight oily sludge building up on it....
is it advisable to adjust the BOV (Greddy type RS recirculated)... never really had a problem with it till now
Old May 10, 2005, 07:51 PM
  #43
03BREvo8's Avatar
well the honey comb reads air flow so if there is anything no it , it will impede that...
Old May 10, 2005, 09:01 PM
  #44
mhgsx's Avatar
Man, what you are experiencing is NORMAL. Even with straight 264's, your idle will sometimes dip. That's just how the stock ECU works. Likes to 'try' different settings.
The only way you're gonna clear that up is with a flash. They pull timing from idle to get it to become more stable.
I had the cams, both straight up and -3/-1.5, and the idle was never fully stable. Ran the Xede for fuel and timing control.
Switched to Dynoflash, idle is dead steady. You wouldn't guess I have cams unless I pointed it out.
Old May 12, 2005, 07:47 AM
  #45
ultraflip's Avatar
thanks for all the responses everyone...
took my car to RRE yesturday... told me my car sounds "****"... so i'm pretty sure that's good.. i like ****...
anyways yeah... they told me i was being paranoid and psychotic... they did fix it though... the turned up my radio for me... =)...
thanks for all your help everyone!
Quick Reply: idle problems! *help! please!!!
