hey guys i have a problem with injen
hey guys i really need some help...i just installed my injen...but when i turn my car on the "service engine soon" light comes on...anybody know what's wrong with it? or something that can cause that light to go on while installing the upper intercooler pipe and the injen intake? any help would be great...the car runs fine...do i need to re program my computer?
Hopefully you didn't damage the maf when taking it apart from the stock box. I know I almost did, it was that hard. Double check and ensure that the maf wiring harness snapps to the maf. If it's not in all the way then it will automatically throw the code. Once this is done, then disconnect the battery to clear the code as cash money suggested. If the code comes back it could be a leak somewhere. If no leak anywhere, take a closer look at your maf and check for damages.
Well, reset the ECU, if the code comes back, get that CEL code pulled, should reveal alot more than just "My CEL keeps coming on"
But check the wiring harness to your MAF, and other connectors, make sure all the wiring and hoses that you disconnected have been reconnected. Its probably nothing major, the pipes are a little time consuming to do, but its unlikely you damaged anything unless you dropped your MAF on a hard surface.
Also do a quick check on the pipes, check for leaks, make sure your DV/BOV is on correctly, all the basic stuff.. I'm sure its nothing but a loose connection.
hey guys thanks for the tips....so i need to disconnect my battery negative side for 10 mins and put it back on? this might take the "service engine soon" light off?
that's what we're here for... hehe... you prolly just turned the car over without everything tightened up... or, left your car turned to on/acc to play the radio while doing this... hehe... i know lot's of ppl that do that... myself no excluded way back in the day
nonschlont
Dec 2, 2009 03:54 PM
Boostin4g63
17
Jul 22, 2007 07:01 PM
