HKS R-Type Intercooler ..is it worth it ?
guys how good is the HKS R-Type Intercooler Kits...some one got it in my town for a customer who never came to pick it up !
he wants to sell it ...dosnt mind to lose some monye.....ok he said to take it for 1100$ it comes with the piping ...but i need to get the SSQV.what do u guys think !!
he said it comes with all the pipes....dont know how i thought it comes with the lower pipes only !
and ya can i use it on the stock turbo or i will get a drop ?
im going to assume you have the stock turbo and in that case most people would say that you're probably going to get a pressure drop and the stock IC works great with whatever mods you're gonna do with the stock turbo so unless you plan on getting a larger turbo in the future I would spend my money elsewhere, but thats just my .02
well what i just bought was 272 cams , K&N drop in , injectors, 255 pump full exhust by JIC , EBC HKS , de cat , and AEM stand alone and some other things here and there.
so its no worth it huh ...!
so u guys say keep it stock huh .... till i change my turbo ....well am thinking AMS but maby after 1 year !
I wouldn't use it with the stock turbo...just b/c you can doesn't mean you would want to...
read the last line from HKS
HKS R-Type intercooler kits are large front mount units that offer the ultimate in cooling capacity. R-Type intercoolers have been engineered to maintain efficiency on applications rated up to 800HP. Measuring 600mm X 302mm in frontal surface area, R-Type front mount intercooler kits maximize cooling efficiency. The 97mm thickness of the core allows for unrestricted internal airflow of pressurized air without affecting external airflow to the radiator. R-Type kits can be used with a stock turbocharger, and are recommended for highly modified turbocharger applications.
get the turbo xs intercooler if any thing. Good quality good price. Now as far as upgrading the intercooler? You dont have to if your are running the stock turbo. The only reason i upgraded mine was because of a little mishap I had with bald rear tyres. The price the dealer wanted for an oem piece you can get an upgrade for cheaper. Plus I am going to change my turbo next month and the stock intercooler just wont do.
Save your money and get the Nisei Engineering intercooler.
http://www.myevostore.com/product_in...roducts_id=276
They will be testing the HKS R-core in a few weeks to see how it measures up to the Nisei IC. Just because it's HKS doesn't mean it's necessarily good. Do your research you'll learn a ton. If you have any questions PM me too. I have a few pics of the HKS intercooler on one of my customer cars (he recently swapped out to a nisei and fixed all his heat soaking issues). The photo you attached above is for the supra core.
thax guys ...thax doktorevo for ur help ...i am doing my research ...but i was getting a good deal for the HKS about 1200 $ for the IC with the lower and uper IC pipes .
thats why ...
about the Nisei cant find some one who would sip it to Saudi Arabia !!!
thats why ...
I want to see the comparison between the HKS and Nisei intercoolers! From the numbers, the HKS seems to be a smaller intercooler:
HKS: 25.61" x 10.07" with 4.06" thickness resulting in surface area of 257.89"^2
Nisei: 25" x 12.62" with unknown thickness resulting in surface area of 316.5"^2
HKS is not a beasty intercooler as many believe it to be.....allthough HKS states it can "support 800hp"...cant many other intercoolers? Support really doesnt mean "very efficient at 800hp"
James@HKSUSA
HKS
Nov 22, 2016 07:01 PM
RallySport Direct
Aug 5, 2005 04:20 PM
