just installed HKS bov
Mine is VTA and I have no problems at all. Idle is the same and and it seems to run the same if not better. It has a chirping and woosh sound at the same time. Getting the bov onto the flange was a *****. I suggest you clamp the ring first(make it not as stiff) before installing it so its easier to pop in.
How is it going from on boost to off boost then back on boost with the throttle? I just got a 2003 with an HKS SSQBOV and I hate it... It is super jerky when you go from on throttle to off...totally upsets the chassis and would never do for road racing. I had the same issue with MR2 turbos using VTA BOVs.
I got mine to work well at trailing throttle-no jerkiness, but the thing would always "hunt" for the idle rpm when I pushed in the clutch. I LOVE the sound, and it holds mad boost.I may reinstall it and try again.
Originally Posted by RalliArtEvoVIII
if i were u, i would connect the vac line straight to the manifold because you're pretty close to that area, prob give better response
ill check it out... thanks for the tip
