10psi wastegate spring ????
Originally Posted by krafty
Try Forge Motorsport, I believe they make them.
this is kinda vague....
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
hmm.... 5-15 psi ?????
Originally Posted by Fourdoor
The stock spring is about 10 to 12 psi....so why you looking for a 10 psi spring?
Keith
Keith
If you unplug vac lines from the stock boost solenoid, disconnect & then block off compressor nipple, and run straight vac to stock wastegate you'll get 11-12psi. Disconnect vac from w/gate totally it would go straight up to higher boost levels.
Forge wastegate springs can only work in the Forge adjustable wastegate actuator!! Our wastegates are not adjustable like that, springs cannot be changed...you can adjust the screw on actuator arm...& get like 2 maybe 3 more psi.
Jay
Jay
thanks for the info.... btw.. what is the name of that selenoid that is attached to the hose ??? (I want to ebay it and would like to put all the right names and nick names for the description)
Originally Posted by EvO6-RS2
Why would u want to auction your stock boost solenoid? If u are using a stock ECU & u take this off your car you'll get a CEL!!
I'm happy to see the turbo will run 10-12 psi because it's all the boost the aluminum block on my honda can take.
jfboy
Jan 2, 2005 06:12 PM
