injen intake and greddy type-s
i mean you can do it without a tune, but once you get the tune you are gonna see more hp untill then it might feel faster and sound alot cooler (yes it does) but it doesnt drive as smooth as it should.
Originally Posted by JSYEVO
will these two work together? the injen intake with upper intercooler piping and the greddy type-s bov? thanks
If you are just going to get the Injen Intake+Greddy BOV, then you will have to buy a flash to make it run right. This has been discussed a bazillion times. If you don't, you'll have bling/sound and less hp. If you do my suggestions, you will gain 30-40hp, and the car will run great. Then, you could get a K&N panel filter ($70) and JDM MR BOV ($120) whenever you get another $200 to spend to flow a little better while holding that increased boost steadily.
Do they work together? WTf. There's like 500 people with these same two mods, who do them for no reason other than to sound and look better, then come back here and ask why their new Evo runs like ***. Take that $400-500, get a boost gauge, MBC, JDM MR BOV, K&N panel filter (or the stock one is just fine).
As it's been said many times, there is absolutely no tuning required for any type of BOV that is recirculated unless the previous BOV was not functioning correctly.
Originally Posted by ct9a gsr
Why do you always crap on people's posts that have to do with anything except for your trusted K&N filter or MR BOV? So what if people want DIFFERENT products for their car? Not everyone wants the same mods as you.
As for the tuning part, I was referring to the intake. Why did you assume I was referring strictly to the BOV?
Originally Posted by gkania
That's Strange, I dropped 2/10 after the Type S and Injen, seems like a power adder to me.
Originally Posted by krafty
So your saying an Injen Intake and Greddy BOV are rice?
That gain is before I had the car reflashed for the parts, I was running higher than stock boost levels, which would necessitate the stronger BOV, the stock BOV has problems with anything over 20psi, hence the power gain, my stock one was leaking. SO I can spend $200 on a nice BOV, or $200 on another OEM Mitsu part that may or may not hold over 25 psi, I'll go with the "rice", you can spend another $200 when your MR starts leaking the first time you turn up the boost with race gas. I guess no one ever told you how to dissect the word "assume". Most people do TBE first since that is the biggest power adder for the money, true the intake costs alot for a little but every little bit helps, put your car on the dyno and watch your stock upper intercooler pipe swell up like a balloon and then tell me if its such a bad idea. Maybe said poster already has the supporting mods already and this is the next logical step for him. In any case, yes they do work well together and YES YOU WILL have gains when setup correctly.
The JDM MR BOV does not cost $200, and it will hold his boost and then some. To overrun that BOV, he will have to be maxing out the stock turbo. If you are running this much boost so as to need a ricey BOV, then you must have put it on AFTER the 12.55@108, right? That mph can be done on stock boost with TBE and a flash. I did 106mph on stock boost/stock exhaust and plan to do 108mph with stock boost/cat-back, even with those crappy IC hoses, plastic BOV, and stock intake box you mentioned.
I was running 22 pounds and my stock BOV was leaking, so I replaced it, and what do you know 2/10. that is my point. It does not say what level of mods he has, just if the two will work together. I guess my titanium exhaust is rice too cause it costs more to do the same thing....... TOO bad it doesnt BLING, Can you get titanim chrome plated???
