Cams with stock exhaust? opinions on my upgrade path..
Just wondering your thoughts. I was either going to go tbe without cams or vice versa. i would like to keep it quiet and dealership friendly.
I'm getting dynoflashed (base flash) in a few weeks and was thinking that i should get flashed for the cams and fuel pump(if i need a pump for cams) then i could add an exhaust later without requiring a reflash.. good plan?
I'm not planning on going crazy with my car but you never know..
tia,
bug
tia,
bug
So you are saving an extra $100 by not having to be reflashed later. I don't think it's worth it. You probably won't even pick up much with the cams by having that restrictive exhaust still on it. I think it's better to get the parts first, and then the correct tune afterwards.
No, bad plan. Exhaust comes way before cams. Fuel pump and cams can come together. You could do the exhaust, not get flashed get cams and pump then get flashed. There is no reason to flash for exhaust only.
There's many reasons why people do exhaust first....But look at it this way. Evos thrive on exhaust flow because of the turbo, the more flow the better. Exhaust gasses can escape much faster with a free flowing exhaust, and the hp gains are noticeable. get a TBE!
sigangee
Feb 21, 2008 08:01 PM
Billy17425
15
May 12, 2006 11:47 AM
