Sticking throttle? RPM's keep rising? Even clutch out!
Old Jun 7, 2005 | 04:56 AM
sschumer's Avatar
Had similar problem a few months ago. Removed upper hose from intake and cleaned butterfly with degreaser, it had gotten all gunked up. Haven't had a problem since.
Old Jun 8, 2005 | 01:31 AM
EVOVII_SWE's Avatar
Originally Posted by plokivos
whatever, that's not what I said. I said it was the maf sensor. Since I had that problem after replacing my clutch.
Zeus made a good sense about how the throttle body opening vs the karman vortex effecting the throttle raising since... i can't remember after that one.
this has been discussed to death on that one forum. It's a common problem.
Few things.
could be your throw out bearing.
could be your intake messing with your MAF Karman vortex.
and few other theory.
search for it on engine section.
Would you then be so kind to explain how this could be related to the throw out bearing as you clearly stated above?
Old Jun 8, 2005 | 01:33 AM
EVOVII_SWE's Avatar
This could very well be a contributing factor, I’ll make sure to check on my car next time I’m working on it.
Old Jun 8, 2005 | 08:46 AM
cruizinmax's Avatar
The throttle cable has to have some play in it. You probably check that first though...right?
nspyr
26
Jun 20, 2017 02:08 AM
Fireescape
Jul 4, 2016 11:18 PM
LeXcite
Dec 5, 2015 02:33 AM
silver_evo
Jul 2, 2013 07:52 PM
sleepy_rps13
Feb 22, 2010 01:37 AM
Quick Reply: Sticking throttle? RPM's keep rising? Even clutch out!
