when does fuel cut come into play
dont try to set any records with the boost # on the gauge, I would hold steady at 25psi, but actually re-set the "maps" to 21-22psi, as this is the "sweet" spot for the evo turbo (stock) and any more you will be running too high with the turbo rpm to be efficent with regards to the HP.
what does ur car do when the cut comes in plus i had no problems until running 1.62 bar or so . my car only showed up in a 4th gear pull wot starting out slow in 4th and bringing it up thru the powerband and about 4k rpm it just coughs harshly
^^^^ yeah... doesn't this have a lot to do with what fuel pump/injectors, ecu setting(flashed, etc), plugs and other mods... may not be able to compare to other cars unless you are apples to apples...
Whenever Im running like 21psi and I lug the motor down going over a bridge in 4th gear at like 65mph, I'll occassionally get a loud, LARGE thud that shake the whole car.....tell me, any ideas?
alright fellas i got rs*r 80mm catback apexi intake with dejon intake pipe , dejon upper intercooler pipe with a greddy type rs bov venting to atmosphere, and a turbo xs hpbc boost controller
i have read: too much boost can "blow" out the spark, causing this, I run the "colder" NGK plugs and they have to be changed all the time, or I get the WOT burps, but I can make the problem go away with the plug change. I am at a loss on this bro, I dont think I can help you, unless you are releasing to the atmosphere too soon. Good luck, and GO STEELERS!!
