how much of a loss in power does a boost leak cause?
Maybe someone can answer this.....
I noticed that the AMS LICP bolts up to the turbo via a black flanged pipe with a small nipple coming out from it. I always thought that this was a stock pipe. Is it not?
I obviously did not buy or install this part. It was on the car when i bought it.
Yes it is the stock pipe. The AMS pipe has a silicone sleave that slides onto the stock black pipe coming off the turbo. Mine AMS lower IC is coming this week.
I have noticed that you can tighten down a clamp and then come back several weeks later and you can tighten it more. I have t-clamps for my IC piping.
I have come to the conclusion that the number one power robbing issue with the EVO is boost leaks. I am changing out some of the stock clamps near the intake and also get those little metal clamps for all the vacuum hoses. I have blown off the vacuum hose to the left of the TB several times. I am hoping this will cure 99% of the leaks. I have had leaks at the TB, intake and IC pipes.
Much of whether or not your car loses boost due to a leak depends on where the boost source for the boost controller is located.
Alot of guys tap in to a feed coming off of the manifold. Tapping into the manifold for this signal will work fine but the effect is that the boost controller will compensate for any leaks that there may be between the compressor discharge and the manifold. The net result is that you may not see the leak manifest itself as a drop in boost (up until a point) and instead you'll push the turbo out of its efficiency island more quickly. Charge temps will go up and if the charge temp is high enough, knock will occur and timing will get pulled resulting in a loss in power.
Tapping into the compressor discharge for boost signal won't get you the rock solid boost that everyone craves if you've got any sort of leak however the pressure at the compressor discharge will remain constant and the turbo will remain in it's efficiency island and will be less prone to blowing hot air.
What I'm trying to get at with my long winded response is that the amount of power lost due to a boost leak depends on alot of factors. Some folks may have a boost leak and not even realize it since their boost guages don't register any taper but in reality they may be losing power due to timing getting pulled.
Originally Posted by titaniumkingpin
so if i were to do a pressure check from the turbo inlet and not get a single leak, would that mean that there are no chances for a boost leak?
Originally Posted by redevo58
I have a boost leak at the flange where the turbo compressor side bolts up to the intercooler piping. I know the cause is my greddy I/C pipe since i just found out after having it on for a year and always having a leak. even after trying several different gaskets . the lower i/c pipe flange was was welded wrong and when trying tpo lay the pipe on a flat surface is does not lie flat but rocks back and forth thus causing the leak. But how much power could i be losing because of this? i already ordered a helix i/c pipe kit to fit the problem.
I have the Buschur Upper IC pipe and it came with a warped flange. After I put the flange on a belt sander to flatten it and reassembled it made a HUGE difference, enough that I could obviously feel it.
Why live with the leak? Just put some high temp silicon seal on the both sides of the gasket and make sure everything is tight and dry before driving. This should solve your leaking prob.
Thanks,
Tom
Thanks,
Tom
I tried that and it still leaked . the actual flange is bents and does not lay flat when placing it on a level surface but rocks back and forth. so there will always be some form of a leak. it always leaks from the same spot since all the gaskets that i've tried always blow out the gasket form the same spot. thats why i just ordered a new intercooler pipe kit form you guys.
I have the 3076r AMS kit running stock 20lbs boost w/ AEM, 272/272, etc... tuned by Martin at AMS, supposed to be making about 400whp & did feel like it before the leak. It pulled like a freight train.
Right now it can only muster 15lbs, AFR at 10.7 likely from the boost leak w/ a sad 226whp/160 ft lbs .
blklbl24
Feb 8, 2012 07:59 AM
AWD_Terror
61
Sep 16, 2009 06:27 AM
EVO8LTW
75
Sep 9, 2005 02:39 PM
