Any "underhood" Methanol explosions yet?
I am 41, so the guy with the GN 20 years ago must be older than me, why are there us old people here? Lawrence Welk not on TV? Dennys closed for rennovation?, I just like to sit here till my "Depends" is full ( it will hold about 18 lbs of urine) and 4 BM's, then I gotta get up and change!jk
Originally Posted by DynoFlash
Just for your information - when I was doing some work on my car a few weeks ago I forgot to attach the - 4 line to the intercooler pipe and I was spraying raw methanol all over my exhuast manifold on the dyno.
The run was too lean and by the time I figured out what was going on there was a huge puddle of methanol on the floor and all over the engine
Of course nothing happend
Sure, methanol is flamable - but so is gasoline
Those who are concerened - that is why the kits that I sell are designed t work on windshield washer fluid or 50% water 50% alcohol mix
havent seen one, but will investigate! I started reading your post, and first thought you are from a foriegn country, was right in the middle of a seizure, or was slipping into a diabetic coma, but I guess this is some kind of line in a movie? I get the humor though, right on!
I really don't think there is that much power to be had with meth over strait alky. You should be able to run a much more aggressive map than just your 93 octane map with 100% alky spraying in.....
i would say make a 93 map, make a 93+alky map, then make a 93+ meth map.
that way, you have a map if your tank gets empty somehow, you have a map thats much better than your pump map everyday on the street, then you have a race day map(which until someone specifies otherwise, i don't think will net more than a few HP more than alky)
check this out:
get the weapon r thing, hook up an low volume inline fuel pump,the aloc. controler, right to the mistors- wholla! you can set this up and run straight aloc. with no prob. ....this would be a much safer set up but would not hold as much go go juice---
btw, is this stuff that much cheaper than sprayin????
Certainly correct me if I am wrong I am a ME not a ChemE but if Methanol follows suit to Nitromethane then it is not as flammable as you may think. You can take an open container of nitromethane or even some really high octane race gasses and toss a match in them and it will extinguich the match. I can not find any data right now to support this but I have not looked real hard either.
Registered User
I thought that was the case with slower burning fuels (less octane) like heating oil, etc. I can't see running a flammable liquid without all of the failsafes a traditional fuel system has.
I dont see how this leak happend. Was the pump on had tight or the line? If it was the pump why would it not leak when the tank was filled? If it was the line it would have only been a small amount due to the check valve next to the pump unless you were driving around with a child under full boost. Also the SMC kit doesnt have an option of spraying under 6 psi which is'nt alot but if you have a child in the car while doing it its a little concernig in itself. So were you getting on it or what I need a few more details before I can really be all that concerned about driving with a child in my car. Not trying to pick apart your story but I'd like to know thanks.
If you read the start of the thread, i tried to start the car over and over again, and it was like it was flooded, that was because the Alky kit was ALSO MIS-wired, the pump was continuously on ( was mis wired to the TPS) and it filled my intake with raw methanol, hence the reason it wouldn't start. Didnt have a drivability problem though driving it OFF boost though, only when I did the exit from the car-wash. I am not a mechanic or a electritian, so I can't really explain much more that this. I had to leave the car at Dyno4mance, as when we started to do the Methanol map, I turned the Key over on the dyno, and Andrew told me to STOP,as he was up front by the pump, and he said he can hear the pump running. ( car wasn't on, key ONLY turned over) He said it the intake is filling up with methanol and the car wouldnt start, I turned the key over, and wallah, it was like it was flooded again (Like a carberated car) So, the hose was finger-tight causing a leak (fixed now-tightened), and the MAP sensor was wired wrong, being fixed on Monday. Hope this helps out!
"Special Fire-Fighting Procedures: Wear approved positive-pressure self-contained
breathing apparatus and protective clothing. Avoid water streams which may
splash and spread flaming liquid. Water spray can be used to reduce the
intensity of the flames and dilute spills to a non-flammable mixture. Vapor may
cause flash fire. Methanol and water mixtures will burn unless very dilute.
Mixtures with 25% or more Methanol are OSHA Class 1 Flammable Liquids."
