Exedy Organic Clutch Kit vs ACT HD Street Disc Kit
#31
Originally Posted by plokivos
act get's my vote all the time.
after... a long time with the act, and probably a lot more miles and launches, it's still holding good @300 whp.
I'm ever so glad that I got the act and nothing else.
my next clutch's going to be act again, since I just don't see any other clutch at that price and the performance.
you guys do use exedy disk i think..?
#33
yeah i guess the act wouldnt be like those double carbon clutches that cost 1600 - 2k+. You wouldnt be able to dump launches into higher rpms...this is a good clutch to dump like you would a oem clutch or maybe a rpm or rpm and half higher i suppose...
#34
#35
Hey,
Good to see our Stage 1 / Stage 2 is getting a little buzz.
Everything Dirk has said about our clutch is fairly accurate, however you must remember - Exedy (Dakin Clutch) is an OEM and and performance clutch company.
Additionally, we are one of the few true manufactures' of clutches in the US (even LUK and Valeo have left the states). Every part we make, be it OEM or performance is built from the ground up as a new unit. If it is an OEM clutch it is to OEM specs - If it is a performance clutch then the focus is on...well, performance.
We too make changes from the OEM clutch when we engineer our performance clutches. Heavy duty UF-91 clutch friction material is used instead of the OEM material and we also increase the clamp load to hold that additional power. However, to take it to the next step we offer our commonly used Twin/Triple/Carbon plates for the person that isn't happy with a mere single disc clutch.
Currently, in my personal vehicle I have a Stage 1 Organic. My car is currently making 390HP/325TQ on a *very* aggressive MD Dyno (AMS 3076). When the car made 286HP/274TQ, it went 12.2... I have yet to make it to the drag strip, but it never slipped *once* on the dyno and stands up to aggressive street launches.
Regardless, I have to admit... I miss haveing my twin plate, and will be returning to it soon. The reason? Well, maybe it can be summed up by "once you go twin... you know nothing else will win"... or something...LOL.
Truely, both ACTs and our Single discs are compraible - I doubt anyone could really pass the "Pepsi challenge" between driving the two (heck, even Ive been duped). However, once you go to a smaller twin disc setup with less inertia - you'll realize what the craze is about. Lightining fast shifting anytime from 4500RPM to 9000RPM, no disengagement problems, EASY driving on the street, lower pedal presure and faster 1/4 mile times... you'll still trap the same, so no it won't make power - but the gains you have from getting rid of the 2nd and 3rd gear "lockouts" or "grinds" or "granny shifts" will net an *easy* .25 seconds on a 1/4 mile ET... my personal estimates are closer to .5 seconds.
All in all, the ACT is a solid clutch and the Exedy stage 1 Stands right next to it.
But if you want *true* performance gains from your clutch, rather than a clutch that will just "hold the power", be sure to check out our line of twin discs...
[/ad campaign off]
[/ad campaign off]
#36
Originally Posted by MattGold
However, to take it to the next step we offer our commonly used Twin/Triple/Carbon plates for the person that isn't happy with a mere single disc clutch...................But if you want *true* performance gains from your clutch, rather than a clutch that will just "hold the power", be sure to check out our line of twin discs...
1. Do twin disks "shock" the car between shifts?
2. Don't twins make more noise?
#37
Originally Posted by 954DRGSR
2 Questions:
2. Twins make an additional noise. Single plate, twin or triple you will still hear drivetrain noise (vibrations transmitted from the motor)... however there is a slight noise of the intermediate (floater) plate "clanking" against the posts that hold the Pressure Plate to the Flywheel.
Hope this helps...
#38
I have had the ACT in my evo for 12000 miles now and love it. I am pushing around 350 to 360whp and no problems. However next week my ams 3071 is going in with alkyd injection soo we will see. Bottom line I would still bye another ACT becuase I am a big fan of it and I have had ACT clutches in all my vws without issues ever.
#39
soo on the street is the exedy twin bad in traffic? I dont know much about it ( I am a little old school) hehehe!!! Would my launches be similar to the act? Is the grab much different? Thanks
#40
Pedal feel would be softer than stock, and launches can be as hard or gentle as you want... in other words it can be slipped or side stepped at the line, its upto you.
#43
I love my twin plate Exedy setup. Drives just like stock and performs like no other! It does require about 700+ miles before the initial chattering noise to go away tho.
#45
exedy oraganic clutch kit is the same as the stock one.
The stock one is an "OEM replacement".
The performance one (Stage 1) has upgraded pressure plate and disc facings... even read Dirk's posts f you don't believe me.
