New Building, New AWD Dyno, New Chassis set-ups.
Old Jul 29, 2005, 08:22 AM
  #46
David Buschur's Avatar
I looked this morning. It is a MD AWD 500 SE. 150 mph max speed, 900 hp capable.
Can't wait to use it.
David Buschur
www.buschurracing.com
Old Jul 29, 2005, 10:39 AM
  #47
dryad001's Avatar
Yup the manual is kinda crazy, I've paged through it a couple times. If you need weights and HP@50 for the loads I can send you a pdf file if you want.
Old Aug 1, 2005, 06:41 AM
  #48
I believe the software has the weights programmed in it, doesn't it? I think that's what they told me.
David Buschur
Old Aug 1, 2005, 07:26 AM
  #49
Precision Dyno's Avatar
Dave the unit comes with an Adobe file with HP@ 50 numbers and wieghts. If you do not have it I will email it to you. Also they only go up to 2002. I have alot of the newer vehicles on disc if you need it including the proper setup for the Evo.
Good luck and let me know if you need anything at all.
Old Aug 1, 2005, 07:29 AM
  #50
You will also have to make sure that every car (that is different) has a new customer base file inputted. AWD mode will need to be selected EVERY time you need to dyno an AWD car.
Check over the Dyno Parameters section also to make sure you have the right inertial and eddy current settings when dynoing.
Just some issues we ran into to try and help..
Old Aug 1, 2005, 07:40 AM
  #51
mike 99gsx's Avatar
I wonder why some dyno company can't incorporate a scale of some sort into the rollers to weigh the car once all 4 wheels are up there? Every modded car is going to weigh a little different depending on how crazy one gets with weight removal.
Old Aug 1, 2005, 08:04 AM
  #52
We picked up a set for that reason. I really don't know why myself...
Old Aug 1, 2005, 08:09 AM
  #53
Truly, thanks for the input guys. I'd like for us MD owners to actually come up with a good system between us so we can see some repeatable results from one dyno to another.
The scales are a really good idea. The MD does do a calculation empty to get an accurate pre-vehicle load.
Thanks again,
David Buschur
Old Aug 1, 2005, 08:15 AM
  #54
Definately, We will talk some more in a couple of weeks when we come up for the event..
Old Aug 2, 2005, 07:53 AM
  #55
DSMu4ia's Avatar
Do you guys have the alignment and corner weighting setup?
Any ideas on cost for both?
Old Aug 2, 2005, 09:21 AM
  #56
We are going to get scales and camber tools once the building is done and we are up and running on the dyno. The floor in this building was poured perfectly flat to enable us to do alignments.
David Buschur
AWD Motorsports
Southeast Region
20
Jan 16, 2009 08:31 AM
Lgkaos
West Region
Aug 17, 2006 10:07 PM
David Buschur
11
Dec 28, 2005 09:39 PM
David Buschur
56
Aug 24, 2005 09:57 AM
David Buschur
63
Jun 29, 2004 06:23 AM
Quick Reply: New Building, New AWD Dyno, New Chassis set-ups.
