Any gain to be had running open downpipe?
Ok im going to the track, i have a 3inch helix exhaust and testpipe. On my silvia i would remove the exhaust after the test pipe (it was also 3 inch) and there was a good gain in spool time, and maybe a tad of power. Has anyone had good results with the on the evo? Its only 2 bolts and the hangers but i had to ask before i try
no more dangerous that running catless.....unless you are parked in a closed garage, you'll be fine
I ahve doine this on an Evo once....spool time with a stock turbo went totally down the drain FWIW
Originally Posted by Thegame
this might be stupid, but running exhaustless from the downpipe could be a little dangerous couldn't it? Are you going to risk getting CO poisoning for a 100th of a second?
I had no issue with spoolup, and I don't see how anyone would have issue with spoolup at the drag strip, since you're never below 5500 rpm...
Originally Posted by Nez136
running leaded gas will mess up your front o2 sensor
Not when the exhaust is disconnected
BTW be careful of fuel cut.. I did this once on stock ECU and car wanted to boost 21psi and would hit fuel cut.
Originally Posted by gsujeff55
you don't disconnect your FRONT o2 sensor.....that wouldn't work too well if you took off the o2 housing
Doh.. your right. hahaha
Most cars i have worked on have both O2s by the cat.. forgot the DSMs have them in the o2 housing.
Anyway.. runing it a few times wont hurt, but it would probably be best to pull the O2 sensor and get a plug for the bung.
