Just installed a Stillway engine dampner
#31
On A Scale Of 1-10 How Noticible Is The Difference As Far Are It Helping With Drivetrain Jerkiness. For Example When You Are On The Throttle And Off And Back On Quickly. Does It Eliminate Some Of The Lurchiness??
#36
Originally Posted by housedj
evo motors (even stock) are known to move up to several inches front/back when getting on it. it's even worse when you remove the balance shafts.
As was just posted above it should not matter which direction it is mounted as the dampening for compression and rebound is most likely the same. If it was going to be valved differntially it would have more rebound dampening, engines torque faster when you close the throtle usually, remember the turbo takes time to come on and provide torque, the throtle closing is immediate.
#37
Originally Posted by NDgsx
Removing the balance shafts will not increase the engine rocking under load, that is due to increased torque.
We'll see if it can handle 500 WHP. That will be the test. I'll throw in some race gas and rip it this weekend.
#38
so, you're saying that aftermarket mani + koyo rad = dented rad?
I just installed koyo rad w/ stock mani and did notice slimmed space between the two.
Anyone had prob w/ koyo rad damage from stock mani?
#39
CAn anyone confirm this.......
I put the two black washers in between the motor mount and bracket. I was confused at first but thought that might be the right place for them. And in the instructions..... there shows two of the two weird looking fat washers (train wheels).
#40
Stock set-up is fine. The Koyo is 57MM and the "thinner" PWR is 37 MM. That is a big difference when it comes to tight spaces. For me it made the difference. But the Koyo was WAY better made. I was sad to see it go.
#45
man, i could have swore that the instructions show the damper being the other way.
